On 06/03/2013 at 07:16, xxxxxxxx wrote:
Hello everybody,
So I have a working script which gets me the nearest object from an arbitrary start point. I am happy with it, but the speed of calculating every object with every object caught me.
If the Object is lowpoly c4d.utils.GeRayCollider() is quiet fast (~1 ms, 1800 polys) but as soon as it gets a highpoly object to calculate it jumps up to high times (~552ms, 440000 polys).
I can't exclude the high poly objects hence I want to check for visibility. Is it possible to speed up c4d.utils.GeRayCollider() even more somehow? I guess I am fishing for help so that my coding marathon was not for nothing.
kind regards mogh
# Ray stuff and nearest obj ------------------------------------------------------------------------------------- def get_ray(start_obj, end_obj, goal) : #modified to accept vectors as start instead of object Global Mg start = ~goal.GetMg() * c4d.Vector(start_obj) end = ~goal.GetMg() * end_obj.GetMg().off return {'ray_p' : start, 'ray_length' : (end - start).GetLength(), 'ray_dir' : (end - start).GetNormalized()} def firerayat (start, direction, length, optemp_test) : # startpoint, direction, length, object to colide collider = c4d.utils.GeRayCollider() collider.Init(optemp_test) #force cache rebuild with , True if collider.Intersect(start, direction, length) : return collider.GetNearestIntersection()["distance"] def get_nearest_obj (start_point, target, obj_list, jump, overal_counter) : micro_time_start = c4d.GeGetTimer() temp_op_distance_list = [] #Reset for obj_rows in obj_list: micro_time_start_a = c4d.GeGetTimer() overal_counter[0] += 1 ray = get_ray( start_point, target, obj_rows[0] ) # has to be calculated everytime hence we need the Matrix of the goal distance = firerayat(ray['ray_p'], ray['ray_dir'], ray['ray_length'], obj_rows[0]) temp_op_distance_list.append([obj_rows[0] , distance]) print overal_counter[0], c4d.GeGetTimer() - micro_time_start_a, " ms internal" try: near_obj = min((e for e in temp_op_distance_list if e[1]), key = itemgetter(1))[0] for i, row in enumerate(obj_list) : if near_obj in row: obj_list[i][2] += 1 # increment the hitcounter except ValueError: near_obj = None print c4d.GeGetTimer() - micro_time_start, " ms" # End ray /////////////////////////////////////////////////////////////////////////////////////
