On 05/03/2013 at 17:03, xxxxxxxx wrote:
I want to select a ring or a loop with SendModelingCommand. Unfortunately, the SKD is very confusing here, leaving it up to find out what some do, or not, by trying http://chicagoc4d.com/C4DPythonSDK/modules/c4d.utils/index.html#c4d.utils.SendModelingCommand For instance there are many indented and duplicate entries under Untriangulate and ConvertSelection, which obviously don´t seem to have to do anything with it?
Then the tools, which in c4d work not on a selection, but also select it (like loop or ring), don´t seem to take notice of MODELINGCOMMANDMODE_****SELECTION (the same as MODIFY_****SELECTION)?
With the ring loop I got "some" achievment by this:
bc = c4d.BaseContainer() bc.SetData(c4d.MDATA_RING_EDGE, 22) # Giving an Edge Id for the ring manually bc.SetData(c4d.MDATA_RING_SELECTION, c4d.SELECTION_NEW) ring = utils.SendModelingCommand(command=c4d.ID_MODELING_RING_TOOL, list=[obj], mode=c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc=bc, doc=doc, flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO) c4d.EventAdd() print ring
But I have to put the edge ID in there manually and got no idea how to find out an edge ID...
Doing the same with Loop Tool just gives me a False feedback, even if I fill out all its options.
bc2 = c4d.BaseContainer() bc2.SetData(c4d.MDATA_LOOP_SEL_STOP_AT_BOUNDS, True) bc2.SetData(c4d.MDATA_LOOP_SEL_SELECT_BOUNDS, False) bc2.SetData(c4d.MDATA_LOOP_SEL_GREEDY_SEARCH, False) bc2.SetData(c4d.MDATA_LOOP_LOOP_EDGE, 11) # bc2.SetData(c4d.MDATA_RING_EDGE, 22) # bc2.SetData(c4d.MDATA_LOOP_SKIP, 0) bc2.SetData(c4d.MDATA_LOOP_SELECTION, c4d.SELECTION_NEW) # bc2.SetData(c4d.MDATA_LOOP_SEL_, 0) loop = utils.SendModelingCommand(command=c4d.ID_MODELING_LOOP_TOOL, list=[obj], mode=c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc=bc2, doc=doc, flags=c4d.MODELINGCOMMANDFLAGS_CREATEUNDO) print loop c4d.EventAdd()
On 05/03/2013 at 17:18, xxxxxxxx wrote:
edge ids are being defined under c4d.polygonobject.getedges().
The edges are indexed by 4 * polygon + edge where polygon is the polygon index and edge is the edge index between 0 and 3.
so the polygon with the id 4 will hold edge 4*4+0, +1, +2, (+3). the edge order is the same as the point order AB, BC, CA or AB, BC, CD, DA.
On 06/03/2013 at 04:27, xxxxxxxx wrote:
Thanks,
for ring selection it kind of works now, but I can´t get a proper undo, it always repeats all the iteration Steps from "for index in select_list:"
doc = c4d.documents.GetActiveDocument() obj = doc.GetActiveObject() select_list = [] neigh = utils.Neighbor() neigh.Init(obj) edgecount = neigh.GetEdgeCount() bs_selected = obj.GetSelectedEdges(neigh, c4d.EDGESELECTIONTYPE_SELECTION) doc.StartUndo() doc.AddUndo(c4d.UNDOTYPE_CHANGE_SELECTION, obj) for i, index in enumerate(bs_selected.GetAll(edgecount)) : if not index: continue else: select_list.append(i) for index in select_list: bc = c4d.BaseContainer() bc.SetData(c4d.MDATA_RING_EDGE, index) bc.SetData(c4d.MDATA_RING_SELECTION, c4d.SELECTION_ADD) # bc.SetData(c4d.MDATA_RING_SKIP, 35) utils.SendModelingCommand(command=c4d.ID_MODELING_RING_TOOL, list=[obj], mode=c4d.MODELINGCOMMANDMODE_EDGESELECTION, bc=bc, doc=doc, flags=c4d.MODELINGCOMMANDFLAGS_0) doc.EndUndo() c4d.EventAdd()
But ID_MODELING_LOOP_TOOL seems broken, or I´m missing something crucial, anybody got luck with that? It doesn´t do anything besides reporting False...
On 11/03/2013 at 12:15, xxxxxxxx wrote:
Got the ring Undo, by doing it in an isolated Document with a combination of DoUndo...
But could anybody test if the ID_MODELING_LOOP_TOOL __ tool is really broken or me? I´ll report it, if its broken...
