On 25/02/2013 at 02:22, xxxxxxxx wrote:
User Information: Cinema 4D Version: R12 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- In order to perform some soft-body deformations using a deformer object, I want to use a mass-spring system applied to the vertices and edges of the polygonized mesh sent to ModifyObject(). My problem is that I definitely do not want to create the mass-spring system every time ModifyObject() is called but only initially and when there are changes to the object being deformed that might require a rebuild of the system. Would GetDirty(DIRTYFLAGS_DATA) be enough? What if the user edits the mesh in some way (for already polygon objects)? What messages might I be looking for in my deformer object from its 'parent' (if any)?
Thanks,
On 28/02/2013 at 12:43, xxxxxxxx wrote:
No one? I had an inkling that checking for DIRTYFLAGS_DATA in ModifyObject() wouldn't work. It updates the system constantly because it is always dirty. It only needs to be done if the user changes some property or the mesh - really, not just to kick in ModifyObject().
Any takers?
On 28/02/2013 at 14:01, xxxxxxxx wrote:
Alrighty, then. After a bit of experimentation, this works the best. I provide this to alleviate the suffering of others in the future.
Note: the mass-spring system is created/recreated in ModifyObject() only because I get a ready-made polygon object.
// ObjectData.CheckDirty //*---------------------------------------------------------------------------* void DeformerObj::CheckDirty(BaseObject* op, BaseDocument* doc) //*---------------------------------------------------------------------------* { if (!doc) return; if (!op) return; // Check Deformed object BaseObject* dop = op->GetUp(); if (dop) { ULONG dd = dop->GetDirty(DIRTYFLAGS_MATRIX|DIRTYFLAGS_DATA); if (dd != dDirty) { dDirty = dd; op->SetDirty(DIRTYFLAGS_DATA); // A data change constitutes a need to recreate Mass-Spring System needInitMassSpring = TRUE; return; } } // Check Collider object BaseContainer* bc = op->GetDataInstance(); if (!bc) return; // - Get linked object BaseObject* lop = (BaseObject* )bc->GetLink(DEFORMER_OBJECT, doc, Obase); if (!lop) return; ULONG dirtyness = lop->GetDirty(DIRTYFLAGS_MATRIX|DIRTYFLAGS_DATA); // - Linked object is not dirty if (dirtyness == cDirty) return; // - is dirty cDirty = dirtyness; op->SetDirty(DIRTYFLAGS_DATA); }
On 01/03/2013 at 00:08, xxxxxxxx wrote:
Hi Robert,
Thanks for sharing the solution.
