On 12/02/2013 at 07:01, xxxxxxxx wrote:
Dear users,
I want to copy a object from one document to my new document, ¿how i do that?.
I know the object´s name and the document´s root, i use a CommandData plugin.
Thanks.
On 12/02/2013 at 07:14, xxxxxxxx wrote:
copyme = doc.SearchObject('myobj') root = otherodc.SearchObject('myroot') copyme.InsertUnderLast(root)
but names are a really bad way to get hold of an object. you should use reference guis like the linkbox or the inexclude list or use the with r14 newly introduced GUID / UIP of a BaseObject.
On 12/02/2013 at 07:18, xxxxxxxx wrote:
Ferdinand, you need to clone the object before you insert it from there, or remove it from the previous document.
-Niklas
On 12/02/2013 at 07:30, xxxxxxxx wrote:
¿I have to open the other document before to copy the object using LoadDocument()?
On 12/02/2013 at 07:35, xxxxxxxx wrote:
of course.
On 12/02/2013 at 11:50, xxxxxxxx wrote:
I have this error: "AttributeError: 'NoneType' object has no attribute 'SearchObject'" with this code: objetc="Brillante" base=documents.LoadDocument(File,c4d.SCENEFILTER_OBJECTS) copy=base.SearchObject(objetc).GetClone() doc.InsertObject(copia) "File" is the root of the base document. Thanks
On 12/02/2013 at 11:59, xxxxxxxx wrote:
file needs to be an absolute document path string -> 'C:\Files\mydocument.c4d'. LoaDocument returns None when the given path does not exist. Therefore base is of the type None in your example.
On 12/02/2013 at 12:02, xxxxxxxx wrote:
Thanks ferdinand
