On 09/02/2013 at 17:59, xxxxxxxx wrote:
Hi all,
Ive got a Plugin-tag and Id like to add or remove userdatas. Adding works, but removing is a problem. I have already tried out various things, but nothing has worked. Here are some naked lines. Which command do I need to update the userdatacontainer immediately?
import os import math import sys import c4d from c4d import plugins, utils, bitmaps, gui # be sure to use a unique ID obtained from www.plugincafe.com PLUGIN_ID = 145268788 #TestID class TagPlugin(plugins.TagData) : def Init(self, node) : return True def Message(self, node, type, data) : if type==c4d.MSG_DESCRIPTION_COMMAND: if data["id"][0].id == 10001: self.AddUD(node) elif data["id"][0].id == 10002: self.RemoveUD(node) return True def Execute(self, tag, doc, op, bt, priority, flags) :# return c4d.EXECUTIONRESULT_OK def AddUD(self, node) : data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL) data[c4d.DESC_NAME] = "Enable" node[node.AddUserData(data)] = False def RemoveUD(self,node) : node.RemoveUserData(1) if __name__ == "__main__": dir, file = os.path.split(__file__) bmp = bitmaps.BaseBitmap() bmp.InitWith(os.path.join(dir, "res", "icon.tif")) plugins.RegisterTagPlugin(id=PLUGIN_ID, str="TagPlugin", g=TagPlugin, description="TagPlugin", icon=bmp, info=c4d.TAG_MULTIPLE|c4d.TAG_EXPRESSION|c4d.TAG_VISIBLE)
Another problem Ive got are separators. For example:
def AddUD(self, node) : data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL) data[c4d.DESC_NAME] = "Enable" node[node.AddUserData(data)] = False data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_SEPARATOR) data[c4d.DESC_SEPARATORLINE] = True node.AddUserData(data) data = c4d.GetCustomDatatypeDefault(c4d.DTYPE_BOOL) data[c4d.DESC_NAME] = "Enable2" node[node.AddUserData(data)] = False
The separators are listed in the UserDataManager but hidden in the interface. I wasn´t able to get a solution. What is wrong?
Thanks in anticipation rown **
On 09/02/2013 at 18:47, xxxxxxxx wrote:
I ran into this same annoying problem trying to remove UD using C++. Apparently the whole tag has to be updated when removing UD. But not when adding them.
Try this:
def RemoveUD(self,node) : node.RemoveUserData(1) c4d.SendCoreMessage(c4d.COREMSG_CINEMA, c4d.BaseContainer(c4d.COREMSG_CINEMA_FORCE_AM_UPDATE))
This is currently not documented in any of the SDK's. But it should be.
On 10/02/2013 at 04:08, xxxxxxxx wrote:
Hello Scott,
the command seems to be brutal, but works perfectly. Thank you very much. One last little question: Do you happen to know the separator-problem, too?
Greetings rown
On 10/02/2013 at 07:53, xxxxxxxx wrote:
Sorry. I can't help with the separator problem. That's a strange one.
On 10/02/2013 at 15:53, xxxxxxxx wrote:
With some persistence I managed to figure it out.
def addSeparator(obj) : if obj is None: return bc = c4d.GetCustomDatatypeDefault(c4d.DTYPE_SEPARATOR) #Create default container bc[c4d.DESC_NAME] = "My Separator" #Rename the entry bc.SetLong(c4d.DESC_CUSTOMGUI,c4d.DTYPE_SEPARATOR) bc.SetBool(c4d.DESC_SEPARATORLINE, False) obj.AddUserData(bc) #Add the userdata container c4d.EventAdd() #Update C4D
Again. Things like this really should be documented better.
On 11/02/2013 at 02:39, xxxxxxxx wrote:
Wow, thank you very much. I'm very excited. Will try tonight.
Greeting rown
