On 08/02/2013 at 10:11, xxxxxxxx wrote:
Hi i have this script for split polygon face:
import c4d from c4d import utils settings = c4d.BaseContainer() res = utils.SendModelingCommand(command = c4d. **MCOMMAND_SPLIT** , list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc) c4d.EventAdd()
but not work... the new poygon is not created... There is something that I entered wrong?
Thanks!
On 08/02/2013 at 10:58, xxxxxxxx wrote:
what could help :
create a copy both of your BaseDocument and your PolygonObject. Insert the poly copy into the copy of the BaseDocument and pass these two to SMC. Then insert the result into your active BaseDocment.
On 08/02/2013 at 11:07, xxxxxxxx wrote:
Try this:
import c4d from c4d import utils settings = c4d.BaseContainer() res = utils.SendModelingCommand(command = c4d.MCOMMAND_SPLIT, list = [op], mode = c4d.MODELINGCOMMANDMODE_POLYGONSELECTION, bc = settings, doc = doc) **doc.InsertObject(res[0])** c4d.EventAdd()
On 09/02/2013 at 01:57, xxxxxxxx wrote:
ferdinand and NiklasR, Thanks for your help
