On 06/02/2013 at 02:14, xxxxxxxx wrote:
Hi all,
Is there a way to make a script that randomizes the order of objects under a null in the object manager?
Grtz, Hans Willem
On 06/02/2013 at 03:14, xxxxxxxx wrote:
Easy:
import random def main() : objs = op.GetChildren() [x.Remove() for x in objs] random.shuffle(objs) [x.InsertUnder(op) for x in objs] main()
Note: no undos
On 06/02/2013 at 03:26, xxxxxxxx wrote:
Wow! Thanks!
On 06/02/2013 at 14:11, xxxxxxxx wrote:
Forgot to add c4d.EventAdd() as the last line of the main() function. This will update the Cinema 4D interface so you can see the change immediately.
