On 03/02/2013 at 14:43, xxxxxxxx wrote:
Hi
i am trying to import some tracking data (faceshift) into c4d. everything works fine, except that i can not get the head-rotation work properly.
the head rotation i get from faceshift is in quaternion format and consist of 4 float values (x,y,z,w)
i tried doing something like this:
newMatrix=c4d.utils.RotAxisToMatrix(c4d.Vector(x,y,z),w) headTarget.SetMl(newMatrix)
i tried a lot with swapping or negating the values x,y,z and w, but had no luck so far.
i know that faceshift and c4d do not use the same coordinates systems (left handed vs right handed), because to get the head-translation correctly i need to negate the z-value.
hope someone can show me the way....
On 03/02/2013 at 15:55, xxxxxxxx wrote:
OK I solved it myself:
Here is how i got it working:
newMatrix = quaternionToMatrix(x,y,z,w) headTarget.SetRelRot(c4d.utils.MatrixToHPB(newMatrix))
def quaternionToMatrix(x,y,z,w) : xx = x * x; xy = x * y; xz = x * z; xw = x * w; yy = y * y; yz = y * z; yw = y * w; zz = z * z; zw = z * w; vec1=c4d.Vector() vec2=c4d.Vector() vec3=c4d.Vector() vecOff=c4d.Vector() vec1.x = 1 - 2 * ( yy + zz ); vec1.y = 2 * ( xy - zw ); vec1.z = 2 * ( xz + yw ); vec2.x = 2 * ( xy + zw ); vec2.y = 1 - 2 * ( xx + zz ); vec2.z = 2 * ( yz - xw ); vec3.x = 2 * ( xz - yw ); vec3.y = 2 * ( yz + xw ); vec3.z = 1 - 2 * ( xx + yy ); newMatrix=c4d.Matrix(vecOff,vec1,vec2,vec3) return newMatrix
here is the link where i found the function: http://web.archive.org/web/20041029003853/http://web.archive.org/web/20041029003853/http://www.j3d.org/matrix_faq/matrfaq_latest.html#Q54
