SNHookClass & MultiLicense
On 01/02/2013 at 07:40, xxxxxxxx wrote:
Cinema 4D Version:   R14
Platform:
I'm implementing the SNHookClass to allow the user enter the license for my plugin. What is the
c4dsn String passed to ~:SNCheck(); when working on a MultiLicense environment?
I'm asking because
  • I can't test it (don't have a MultiLicense environment lying around..)
  • GeGetSerialInfo() can be called for either retrieving the MutltiLicense or the
    generous license.
Is it the 11 digits only and I have to manually check for a MultiLicense, or will be it be the 18
characters long MultiLicense string (12345678912-ABCDEF) ?
Thank you,
Niklas
On 01/02/2013 at 08:14, xxxxxxxx wrote:
Header
// KDZSerial.h
// Serial Number handling
// V0.1 2011.04.21 Robert Templeton
// Includes
#include "general.h"
#include "lib_sn.h"
// KDZSerial: Serial Number Hook Class
class KDZSerial : public SNHookClass
 private:
     // Data
     char            pcode[6];
     const String    SNPluginName;
     // Methods
     Bool            checkSerial(const String& c4dsn, const String& sn);
 public:
     // Data
     // - mode = 0 (not registered/not demo), 1 (demo), 2 (registered), 3 (C4D demo)
     UCHAR            mode;
     LONG            time;
     // Methods
     KDZSerial();
     LONG            SNCheck(const String& c4dsn, const String& sn, LONG regdate, LONG curdate);
     void            setPluginCode(const char* t_pcode);
     const String&    GetTitle();
// KDZSerial.cpp
// Includes
#ifdef MACOS
  #include "Rijndael_Mac.h"
#else
  #include "Rijndael.h"
#endif
#include "KDZSerial.h"
// Size of serial number string
#define ENTRY_SIZE                17
// Methods
// - Constructor
KDZSerial::KDZSerial() : SNPluginName(GeLoadString(KDZS_PLUGIN_NAME))
  mode =            0;
// - KDZSerial.setPluginCode
void KDZSerial::setPluginCode(const char* t_pcode)
  memcpy(pcode, t_pcode, 6);
// - KDZSerial.checkSerial
Bool KDZSerial::checkSerial(const String& c4dsn, const String& sn)
  // Key is 11-Digit C4D SN + 5-Char PluginCode + NullTerminator
  char key[ENTRY_SIZE];
  c4dsn.GetCString(&key[0], c4dsn.GetCStringLen()+1L, STRINGENCODING_7BIT);
  memcpy(&key[11], &pcode[0], 6);
  // Encrypt plugin serial no. using AES
  char dout[ENTRY_SIZE] = "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0";
  // One block testing
  CRijndael oRijndael;
  if (!oRijndael.MakeKey(&key[0], "\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0\0", 16, 16))
      return MessageSystem::Throw(GeLoadString(KDZERR_GENERAL), GeLoadString(KDZERR_SNMAKEKEY));
  char din[ENTRY_SIZE];
  memcpy(&din[0], &key[0], ENTRY_SIZE);
  if (!oRijndael.EncryptBlock(din, dout))
      return MessageSystem::Throw(GeLoadString(KDZERR_GENERAL), GeLoadString(KDZERR_SNENCRYPTION));
  dout[16] = 0;    // Null-terminate
  UINT    i;
  UCHAR    val;
  // Convert to AlphaNumerics for user serial number entry
  for (i = 0; i != 16; ++i)
      val =    (UCHAR)dout[i];
      // Beyond AlphaNumerics
      if (val > 122)                    val /= 3;
      // Below AlphaNumberics
      if (val < 48)                    val += 48;
      // Between numerals and UC Alpha
      if ((val > 57) && (val < 65))    val += 24;
      // Between UC Alpha and LC Alpha
      if ((val > 90) && (val < 97))    val += 12;
      dout[i] =    (char)val;
  sn.GetCString(&key[0], sn.GetCStringLen()+1L, STRINGENCODING_7BIT); //ENTRY_SIZE, St7bit);
  // Check sn against Encrypted-AlphaNumericized dout
      //GePrint("key["+LongToString(i)+"]=\'"+LongToString(key[i])+"\' == chk["+LongToString(i)+"]=\'"+LongToString(dout[i])+"\'");
      if (key[i] != dout[i])
          return MessageSystem::Throw(GeLoadString(KDZERR_GENERAL), GeLoadString(KDZERR_SNINVALID));
  return TRUE;
// - SNHookClass.SNCheck
LONG KDZSerial::SNCheck(const String& c4dsn, const String& sn, LONG regdate, LONG curdate)
  if (!sn.Content())    return SN_WRONGNUMBER;
  // Demo mode (30 day trial)
  if (sn.GetLength() == 4L)
      // Case-insensitive serial number 'demo'
      String    demo =                sn.ToLower();
      if (demo.Compare("demo"))    return SN_WRONGNUMBER;
      if (!regdate)
          mode =    1;
          return SN_OKAY;
      // Calculate timeout of Demo mode
      // - elapsed time since registering demo
      LONG    exptime =        curdate - regdate;
      // - Number of demo days
      LONG    expiration =    30L;
      LONG    timeout =        expiration-exptime;
      if (timeout < 0L)        return SN_EXPIRED;
      time =                    timeout;
      mode =                    1;
      if (exptime >= (expiration-3L))    return SN_EXPIRE_14 - timeout;
      return SN_OKAY;
  // Registered user
  else if (sn.GetLength() == 16L)
      if (checkSerial(c4dsn, sn))
          mode =    2;
          return SN_OKAY;
#ifdef    C4D_R11
  // Multi-License Server
  else
      // Check for R11 Multi-License
      SerialInfo    mlsn;
      GeGetSerialInfo(SERIALINFO_MULTILICENSE, &mlsn);
      if (mlsn.nr.Content())
          // Note that we also need to skip over the extra data added to the front of the
          // plugin's license key (11 digits/characters and a dash)...
          String    plug_sn =    sn;
          LONG dashPos;
          if (plug_sn.FindFirst("-", &dashPos, 0L))
              plug_sn = plug_sn.SubStr(dashPos+1L, plug_sn.GetLength()-dashPos-1L);
              if (checkSerial(mlsn.nr, plug_sn))
                  mode =    2;
                  return SN_OKAY;
#else
  else    MessageSystem::Throw(GeLoadString(KDZERR_GENERAL), GeLoadString(KDZERR_SNSIZE));
#endif
// - SNHookClass.GetTitle
const String& KDZSerial::GetTitle()
  return SNPluginName;
// Main.cpp
// SymMorphy
// V0.1 2011.05.25 Robert Templeton
// Includes
// - To allow future demo for users who have already demoed a previous version
// - Note that it is in the code to avoid user changing ID
enum
  ID_SYMMORPHY_DEMO        =    1029219
static KDZSerial* kdzSerial =    NULL;
Bool RegisterKDZSerial()
  kdzSerial =            gNew KDZSerial();
  if (!kdzSerial)        return MessageSystem::Throw(GeLoadString(KDZERR_MEMORY), "Main.RegisterKDZSerial.kdzSerial");
  char    pcode[6] =    "symmy";
  kdzSerial->setPluginCode(&pcode[0]);
  if (!kdzSerial->Register(ID_SYMMORPHY, SNFLAG_OWN))
      return kdzSerial->Register(ID_SYMMORPHY_DEMO, SNFLAG_OWN);
  return TRUE;
void FreeKDZSerial()
  gDelete(kdzSerial);
// Plugin Functions ==================================================================================================
#include "SymMorphyDoc.h"
// Declare Global Plugin Registrants
Bool            RegisterSymMorphyTag();
SymMorphyDoc*    RegisterSymMorphyDoc();
Bool            RegisterSymMorphySceneHook();
static SymMorphyDoc*    symmorphydoc =        NULL;
Bool PluginStart()
  Bool    network =                                        FALSE;
#ifdef    C4D_R12
  VERSIONTYPE    vtype =        GeGetVersionType();
  SYSTEMINFO    stype =        GeGetSystemInfo();
  if ((vtype == VERSIONTYPE_NET_SERVER_3) || (vtype == VERSIONTYPE_NET_SERVER_UNLIMITED) || (vtype == VERSIONTYPE_NET_CLIENT))    network = TRUE;
  if        (stype & SYSTEMINFO_DEMO)        GePrint("C4D Demo");
  else if (stype & (SYSTEMINFO_SAVABLEDEMO|SYSTEMINFO_SAVABLEDEMO_ACTIVE))                        GePrint("C4D Savable Demo");
#ifdef    C4D_R13
  else if (stype & (SYSTEMINFO_SAVABLEDEMO|SYSTEMINFO_STUDENT))                                    GePrint("C4D Student Demo");
#endif
  else if (stype & SYSTEMINFO_COMMANDLINE)                                                        GePrint("C4D CommandLine");
  else if ((vtype == VERSIONTYPE_NET_SERVER_3) || (vtype == VERSIONTYPE_NET_SERVER_UNLIMITED))    GePrint("C4D Server");
  else if (vtype == VERSIONTYPE_NET_CLIENT)                                                        GePrint("C4D Client");
  else
      // serial number check
      if (!(kdzSerial && kdzSerial->mode)) return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart:serial check failed!");
#elif defined    C4D_R11
  LONG    vtype =                                            GeGetVersionType();
  if ((vtype & VERSION_SERVER) || (vtype & VERSION_NET))    network = TRUE;
  if        (vtype & VERSION_DEMO)                            GePrint("C4D Demo");
  else if (vtype & VERSION_SAVABLE)                        GePrint("C4D Savable Demo");
  else if (vtype & VERSION_SERVER)                        GePrint("C4D Server");
  else if (vtype & VERSION_NET)                            GePrint("C4D Net");
  else if (!(kdzSerial && kdzSerial->mode))                return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart:serial check failed!");
#else
  if (!((vtype & VERSION_DEMO) || network))
#endif
  GePrint(" ");
  GePrint(GeLoadString(KDZS_PLUGIN_BANNER));
  GePrint("-- "+GeLoadString(KDZS_PLUGIN_NAME)+GeLoadString(KDZS_PLUGIN_EDITION)+"v"+GeLoadString(KDZS_PLUGIN_VERSION)+" "+GeLoadString(KDZS_PLUGIN_COPYRIGHT));
  if (kdzSerial)
      if        (kdzSerial->mode == 1)                        GePrint("-- Trial: "+LongToString(kdzSerial->time)+" days left");
      else if (kdzSerial->mode == 2)
          SerialInfo    si;
          GeGetSerialInfo(SERIALINFO_CINEMA4D, &si);
          GePrint("-- Licensed to: "+si.name);
  GePrint(" ");
  // Register hooks and return
  // - SymMorphy Demo or Registered
  symmorphydoc =                                            RegisterSymMorphyDoc();
  if (!symmorphydoc)                                        return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart.RegisterSymMorphyDoc() failed!");
  if (kdzSerial)
      if (!symmorphydoc->Initialize(network, kdzSerial->mode, kdzSerial->time))    return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart.SymMorphyDoc.Initialize() failed!");
  // - Cinema 4D Demo
  else
      if (!symmorphydoc->Initialize(network, 3L, 2147483647L))    return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart.SymMorphyDoc.Initialize() failed!");
  if (!RegisterSymMorphyTag())                                return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart.RegisterSymMorphyTag() failed!");
  if (!RegisterSymMorphySceneHook())                            return ErrPrt(GeLoadString(KDZS_PLUGIN_NAME)+".Main.PluginStart.RegisterSymMorphySceneHook() failed!");
  return TRUE;
void PluginEnd()
Bool PluginMessage(LONG id, void* data)
  if        (id == C4DPL_INIT_SYS)
      // initialize global resource object
      if (!resource.Init())    return ErrPrt("Main.PluginMessage.resource.Init() failed!");
      Bool    serial =        TRUE;
      // initialize and register Serial Number Hook
#ifdef    C4D_R12
      if        (stype & SYSTEMINFO_DEMO)                                                            { GePrint("C4D Demo");            serial = FALSE; }
      else if (stype & (SYSTEMINFO_SAVABLEDEMO|SYSTEMINFO_SAVABLEDEMO_ACTIVE))                    { GePrint("C4D Savable Demo");    serial = FALSE; }
#ifdef    C4D_R13
      else if (stype & (SYSTEMINFO_SAVABLEDEMO|SYSTEMINFO_STUDENT))                                { GePrint("C4D Student Demo");    serial = FALSE; }
#endif
      else if (stype & SYSTEMINFO_COMMANDLINE)                                                    { GePrint("C4D CommandLine");    serial = FALSE; }
      if ((vtype == VERSIONTYPE_NET_SERVER_3) || (vtype == VERSIONTYPE_NET_SERVER_UNLIMITED))        { GePrint("C4D Server");        serial = FALSE; network = TRUE; }
      else if (vtype == VERSIONTYPE_NET_CLIENT)                                                    { GePrint("C4D Net");            serial = FALSE; network = TRUE; }
      if        (vtype & VERSION_SERVER)    { GePrint("C4D Server");        serial = FALSE; network = TRUE; }
      else if (vtype & VERSION_NET)        { GePrint("C4D Net");            serial = FALSE; network = TRUE; }
      else if    (vtype & VERSION_DEMO)        { GePrint("C4D Demo");            serial = FALSE; }
      else if (vtype & VERSION_SAVABLE)    { GePrint("C4D Savable Demo");    serial = FALSE; }
#else
      if        (vtype & VERSION_SERVER)    { serial = FALSE; network = TRUE; }
      else if (vtype & VERSION_NET)        { serial = FALSE; network = TRUE; }
      else if (vtype & VERSION_DEMO)        { serial = FALSE; }
#endif
      // Allocate SymMorphy Data Storage
      if (serial) return RegisterKDZSerial();
      else        return TRUE;
  else if (id == C4DPL_ENDACTIVITY)
      FreeKDZSerial();
      return TRUE;
  else if (id == C4DMSG_PRIORITY)        return TRUE;
  return FALSE;
// Return SymMorphyDoc* symmorphydoc - globally accessible
SymMorphyDoc* GetSymMorphyDoc()
  return symmorphydoc;
On 01/02/2013 at 08:15, xxxxxxxx wrote:
Giblet has a very informative post here that outlines the required format of the serial number for the Maxon License Server for plugin registration. The post is: "R11 License Server & SNHookClass"
On 05/02/2013 at 15:09, xxxxxxxx wrote:
@NiklasR:
Here is the Link to "R11 License Server & SNHookClass", mentioned by Robert.
Indeed a very informative thread.
And there is a 5 part tutorial about licensing plugins at the "C4D Programming Blog" that also might be interesting for you to read.
Even though there is no extra information about a License Server implementation to find.
@kuroyume0161:
Thank you Robert for your whole licensing source code(s).
I already have a working solution for myself but I think I'll take a look at yours too and maybe could get some ideas for improvements of my own.
E.G. I still wasn't able to implement a time limited demo mode that really would work as expected.
On 06/02/2013 at 03:33, xxxxxxxx wrote:
Great to have another open piece of source code for C4D !
Thank you! Lets lock what new I can learn from it.
May be we could start GitHub for all the code? :)
On 06/02/2013 at 03:42, xxxxxxxx wrote:
Thank you very much for the reference, Robert! :beer:
+ 1 !!!!!
I already have some C4D related stuff on my GitHub profile:  https://github.com/NiklasRosenstein
On 06/02/2013 at 04:00, xxxxxxxx wrote:
I have some code here:
http://code.google.com/p/code-editor-gui/source/browse/
