On 26/01/2013 at 09:07, xxxxxxxx wrote:
i have got a BaseTag for which i have to throttle the tag execution for performance
reasons. i am using a custom isdirty method, with which i am comparing the currrent
state of the tag and its linked objects with a cached state. to do this, i also cache the
basecontainer of the tag to compare this cache with copies of the tag basecontainer
created at a later point.
my tag contains LinkBoxGui and a InExcludeCustomGui elements. when i compare
these containers against each other the result is always False, unless i clear out
the link values before i store my bc cache.
is this intended ? shouldn't __eq__ compare the objects cotained in the link fields in
a boolean manner (or ignore them) rather than checking if they are actually the same
object with the same memory address ? are my assumptions correct or am i doing
something wrong here ?
class foo(object) :
def __init__(self) :
self.Cache = None
def methodA(self, node) :
self.Cache = node.GetData()
def methodB(self, node) :
# always true
if self.Cache != node.GetData() :
pass
a link to the complete isDirty() method.
