On 23/12/2012 at 07:05, xxxxxxxx wrote:
Hi
i have this example script COFFEE:
//This script reads the text from a file called "position.txt" on the desktop and converts the string to a float value //Then uses it to position the currently selected object // NOTE: Make sure there are no spaces in your text file or you will get an error var name = doc->GetFilename(); name->SetFullString("C:/Users/user/Desktop"); name->AddLast("values.txt"); var filename = name; var file = new(BaseFile); file->Open(filename, GE_READ); var str = file->ReadString(file->GetLength()); var pos = file->GetPosition(); // Gets total number of characters var seek = file->Seek(4,false);// Gets the fourth character var read = file->ReadString( seek+1, GE_XBIT );// reads the fourth and fifth characters var y = evaluate(read); //Converts string info from the file into a float value op#ID_BASEOBJECT_REL_POSITION:VECTOR_Y = y;// Set the Y position to this value
how is possible to convert this scritp in Python?
I Have search in python documentation but to no avail....
Thanks
On 23/12/2012 at 09:01, xxxxxxxx wrote:
i have find!
import c4d from c4d import gui import os #Welcome to the world of Python
def main() :
linestring = open('D:/Personal/Desktop/values.txt', 'r+') #File linestring.seek(0,5) #cursor point hello = linestring.read(4) #read # Stampa print hello
if __name__=='__main__': main()
