store data with the document
On 17/12/2012 at 16:01, xxxxxxxx wrote:
info : R14, Vista64, Python
hi,
i have got a stupid question again. i have got a command plugin generating data for a
c4d file stored in a multilevel BaseContainer. currently i am saving these data with a
hyperfile which is a bad solution, because renaming or moving the c4d file breaks the
connection between the data and the c4d file. so i am looking for a better place now.i want :
- to store the data within the file
- the data not to be visible to the user (as a object, material or tag node)
possible ways i have been looking into :
- use BaseDocument.SetData()
- is this way even possible ?
- i have tried the following simple example:
* console output: * SystemError: source\pymodules\c4d\PyBaseContainer\PyBaseContainer.cpp:1095: bad argument to internal function * * * import c4d * * def main() : * bc = c4d.BaseContainer() * bc.SetBool(c4d.DOCUMENT_RENDERLOD, True) * doc.SetData(c4d.DOCUMENT_RENDERLOD, bc) * * if __name__=='__main__': * main() *
3. so, how is the correct way to feed this method ? 4. can i use own type ids and which id would i have to use without conflicting with other ids ? my plugin id ?
- use a NodeData plugin
- is it possible to create some NodeData subtype plugin type and add it in *hidden* mode into the document ?
- the sdk says it is even possible to inherit from c4d.plugins.nodeData itself, but when i do so, my plugin hasn't any access to the methods provided by NodeData.
sorry for this bunch of questions, but i have really tried to solve this on my own without any real
success. i would be really thankful for a push into the right direction. i have also tried the search
function on this without any useable result.thanks for reading and any help.
On 18/12/2012 at 00:28, xxxxxxxx wrote:
Hi Ferdinand,
To easily save data within a document or object, check this post.
This is the simplest way in Python but remember that the ID to store the data has to be unique;
generate it like a plugin ID.BaseDocument.SetData() is only useful with the defined document settings.
Originally posted by xxxxxxxx
console output: SystemError: source\pymodules\c4d\PyBaseContainer\PyBaseContainer.cpp:1095: bad argument to internal function import c4d def main() : bc = c4d.BaseContainer() bc.SetBool(c4d.DOCUMENT_RENDERLOD, True) doc.SetData(c4d.DOCUMENT_RENDERLOD, bc) if __name__=='__main__': main()
In Python you can just do this:
import c4d def main() : doc[c4d.DOCUMENT_LOD] = 0.5 c4d.EventAdd() if __name__=='__main__': main()
So, basically the operator [] is the way to go when dealing with parameters and the CINEMA API.
On 18/12/2012 at 04:26, xxxxxxxx wrote:
thanks
