Setting BORDER_OUT on tag BitmapButtons?
On 17/12/2012 at 15:08, xxxxxxxx wrote:
Cinema 4D Version:   13
Platform:   Windows  ;
Can anyone tell me how to set the BORDER_OUT option for a bitmap button that's on a tag?
Oddly enough. I can create a copy of the button and then set the BORDER_OUT option just fine.
But I can't figure out how to do it to the original bitmap button.
//The .res file
BITMAPBUTTON IMG_BUTTON {ANIM OFF;}
//The .cpp code
Bool SimpleTag::GetDDescription(GeListNode *node, Description *description,DESCFLAGS_DESC &flags)
  BaseTag *tag = (BaseTag* )node;
  BaseContainer *data = tag->GetDataInstance();
  if (!description->LoadDescription(node->GetType())) return FALSE;
  const DescID *singleid = description->GetSingleDescID();
  DescID cid = DescLevel(IMG_BUTTON, DTYPE_BUTTON, 0);       //My bitmap button's ID is "IMG_BUTTON"
  BaseContainer bmbBC;
  if (!singleid || cid.IsPartOf(*singleid,NULL))             //important to check for speedup c4d!
      bmbBC.SetLong(DESC_CUSTOMGUI, CUSTOMGUI_BITMAPBUTTON); //<--This makes a copy of the bitmap button
      bmbBC.SetLong(BITMAPBUTTON_BORDER, BORDER_OUT);        //The copy has an out border... but original button does not!?
      bmbBC.SetBool(BITMAPBUTTON_BUTTON, TRUE);
  if (!description->SetParameter(cid,bmbBC,DescLevel(ID_OBJECTPROPERTIES))) return FALSE;
  flags |= DESCFLAGS_DESC_LOADED;
  return TRUE;
On 17/12/2012 at 17:41, xxxxxxxx wrote:
might be a bit simple, but have you tried to return a call to the parent class instead
of a straight True ?
return SUPER::GetDDescription(node, description, flags);
the sdk also says :
Note:  Only return [FALSE](file:///D:/Incoming/help/pages/ge_sys_math/enum_BoolConstants150.html#FALSE1) if a massive error occured, e.g. a failed memory allocation. Don't return [FALSE](file:///D:/Incoming/help/pages/ge_sys_math/enum_BoolConstants150.html#FALSE1) if a description parameter can't be found for instance.
On 17/12/2012 at 18:12, xxxxxxxx wrote:
Calling to the SUPER class has no bearing on changing the bitmap button's options.
I wish it was that simple.
On 17/12/2012 at 22:03, xxxxxxxx wrote:
Ugh. Unbelievable.
I've managed to figure it out. And boy was this thing obscure and hard to figure out.
I feel like I just gave birth.......................................To an accountant! :joy:
  DescID cid = DescLevel(IMG_BUTTON, CUSTOMDATATYPE_BITMAPBUTTON, 0);
  BaseContainer bmbBC = GetCustomDataTypeDefault(CUSTOMDATATYPE_BITMAPBUTTON);
  return TRUE;
