Windows SSL Module
On 15/12/2012 at 19:14, xxxxxxxx wrote:
Hey folks!
Seems that the ssl module is not compiled with C4D Python under Windows.
Is there a technical or legal reason for this?
I keep getting this under Windows 7 x64:
**ImportError: ** No module named _ssl
A direct import produces the same. On OS X, everything seems to work fine. Maybe there is a way around it that some of you may know of? I have come up with a few hacks but it requires the user to jump
over some hurdles that I really want to avoid.
Thanks!
On 17/12/2012 at 02:02, xxxxxxxx wrote:
On Windows, C4D Python is not shipped with a native SSL support due to some internal dependencies.
The SSL module has a dependency to OpenSSL which is part of OS X but not Windows. You can compile the missing libs (_ssl.pyd)
from Python manually with VS2010 (R14) or VS2005 (R13) and add the file to a sub-folder of your plugin.
The sub-folder must be added to the search path list so Python can find it on an import.
On 18/12/2012 at 19:41, xxxxxxxx wrote:
Thanks for the reply Yannick!
I'm going to try compiling the module.
Cheers!
On 20/12/2012 at 03:14, xxxxxxxx wrote:
Hi 990adjustments,
I also ran into this earlier. It seems to be important that the exact same version of python (6.6.4) and visual studio (2005 for r12/r13 and 2010 for r14) are used. I started doing an attempt a while ago, but always got stuck at some point. If you succeed in getting this to run, it would be great if you could share it!
Just out of curiosity: What are you using it for? I was trying to use https to connect to a web service.
Best
Timm
On 21/12/2012 at 20:15, xxxxxxxx wrote:
Hey tdapper,
I will definitely share the results if successful.
So far all attempts have failed.
On 23/12/2012 at 10:39, xxxxxxxx wrote:
Hi 990adjustments,
keeping my fingers crossed. Will let you know in case we move forward here. Still, it would be really great if MAXON could include this by default...
Timm
