Fill GeDialog combo box dynamically ?
On 12/12/2012 at 09:42, xxxxxxxx wrote:
INFO : C4d r14, Windows Vista 64, Python
hm,
sorry it is me again :) Is it possible possible to fill a GeDialog ComboBox dynamically with
children / entries after the execution of GeDialog.CreateLayout() ? I have got the
following :# dialogContainer is a BaseContainer containg the current dialog settings # self.Presets is a BaseContainer containing several Bc of the same structure # cHelp is a namespace to some c4d related methods. the whole chain is called # from GeDialog.Command() : # # the bc is saved to file ... # -------------------------------------------------------------------------------------------------------------- def savePreset(self, dialogContainer) : presetName = c4d.gui.InputDialog('Preset name:','myPreset {0}'.format(len(self.Presets))) dialogContainer.SetString(1000, presetName) self.Presets.SetContainer(1000 + len(self.Presets), dialogContainer) result = cHelp.SaveHyperFile(self.Presets, self.PresetFilePath, self.HyperKey, True) if(result) : self.fillComboBox() print self.SetLong(srCon.IDC_PRESET_COMBOBOX, len(self.Presets)) return result # and loaded back here. the ccombox is populated with the new preset names # -------------------------------------------------------------------------------------------------------------- def fillComboBox(self) : result = cHelp.ReadHyperFile(self.PresetFilePath, self.HyperKey, True) if(type(result) == c4d.BaseContainer) : self.Presets = result self.FreeChildren(srCon.IDC_PRESET_COMBOBOX) counter = 0 for item in self.Presets: # here i am adding the children, and trying to tell c4d that something had changed. # had the flush and changed thingie on a higher level first, but then moved them here # to be ultrasafe. self.LayoutFlushGroup(srCon.IDC_PRESET_COMBOBOX) self.AddChild(srCon.IDC_PRESET_COMBOBOX , counter, item[1].GetString(1000)) self.LayoutChanged(srCon.IDC_PRESET_COMBOBOX) return True else: return False
I am feeling pretty lazzy for just asking again, but i am not sure what is going wrong there.
When i execute the plugin, everything works as expected. I save the dialog settings to a
hyper file and load the content back from the hyperfile. The combobox is also populated as
expected with my preset names, BUT i cannot visually select anything except the first child.
Programmatically i can set the combobox to any value i want and is also accepted and
returned correctly (but also not reflected in the gui).thanks for your help, as always.
On 13/12/2012 at 02:54, xxxxxxxx wrote:
Have you tried removing the calls to LayoutFlushGroup() and LayoutChanged()?
On 13/12/2012 at 04:41, xxxxxxxx wrote:
do you mean this in in a special context ? because i am calling both in my fillComboBox()
loop for each preset found and added, as shown in the snippet. also i am not quite
sure if i am qusing them both correctly. do they actually expect a group ? i am just
passing the ComboBox.
counter = 0
# to be ultrasafe.
return FalseIt seems you return True from inside the loop. This is maybe why you can only select the first child.
On 13/12/2012 at 05:52, xxxxxxxx wrote:
sorry about that, that is just a typo I introduced, because the copy/paste messed up
the indentions (if the true would be there the combobox wouldn always just contain
one element , but i have all elements, but i can just select the first).before :
selection:
after :
On 13/12/2012 at 06:51, xxxxxxxx wrote:
lol stupid me, if forgot to increase my counter variable and therefor all entries have the same
