Reloading Dialog??
On 12/12/2012 at 08:06, xxxxxxxx wrote:
Trying to build a custom tool with the GeDialog functions inside a script instead of a plugin. The problem is I have to close and reopen C4D if I want to see any updates to the Dialog for some reason. Not sure why.
Tried importing script as a module, but C4D won't recognize the script as a module either; so reload() is out of the question I guess.
Is there a reload function I am not seeing here in the help docs?
Thanks for the help.
Rick
On 12/12/2012 at 08:46, xxxxxxxx wrote:
I didn't understand where you are building the dialog. In a separate file?
On 12/12/2012 at 12:52, xxxxxxxx wrote:
i am also not quite sure what you do mean, but you are aware of sys.path or modules folder
at user/blahblah/ ... Cinema4d/... blah ... /python/modules ? you can't add modules add
runtime, but you can for sure create a Desktop/myModule.py and use it in c4d, you have just
add the Desktop to your sys.path list.
On 12/12/2012 at 13:05, xxxxxxxx wrote:
Sorry I am building the Dialog inside the Script Manager and saving it out to the scripts folder for C4D.
Importing, reloading and running with the following syntax:
import [script name]
reload[script name]
script name . run functionI just keep getting an error saying 'No module named [script name here]'. Coming from the scripting world in Maya, this was all I ever had to do, was save it inside the scripts folder. I am going to look into the sys.path stuff more though, I just figured it would be built in for C4D to read modules from its own scripts folder.
On 12/12/2012 at 13:36, xxxxxxxx wrote:
it is still not 100% clear to me what you want. since you are talking about modules,
i assume you are talking about multiple files. lets assume you have got 2 files.c://myModule.py
myScriptfile.pymyScriptfile.py doens't have to be physically on your hardrive you can also create just in
the memory within the document. the import statements for myScriptfile.py would be :import sys, os __mypath__ = 'c:\\' if __myPath__ not in sys.path: sys.path.insert(0, __myPath__) import c4d, myModule ...
however, i am 100% sure one of the more experienced guys here will come arround
and tell us, that absolute paths are bad. so normally you would do something like that :import sys, os # that line is just working in a script/tag or node, for a plugin we had to use c4d.documents # and so o. also the document has to be saved at leasst once, otherwise doc.GetDocumentPath() # will be "". if doc.GetDocumentPath() not in sys.path: sys.path.insert(0, doc.GetDocumentPath()) import c4d, myModule or like this __currdir__ = os.path.join(os.path.dirname(__file__) , 'modules') if __currdir__ not in sys.path: sys.path.insert(0, __currdir__) import c4d, myModule
you can also just drop the script into the c4d usersettings python modules folder.
ps : also note that python sometimes needs a __init__.py file (no content)
in the folder you want to become a module folder. i also never understood when
they have to be created and when not, so i just drop them here and there :)pps: just to make it really clear. myModule.py has to exist before c4d has been started.
Any changes made to myModule.py while C4d is running , won't take any effect before
C4D has been restarted again.
