Convert int ID back into string representation ?
On 10/12/2012 at 05:15, xxxxxxxx wrote:
hi,
i have got a quite simple question again. is there a way to convert a plugin or basecontainer
ID from their integer form back into the alphanummeric form defined in the header files ? i want
to pass an integer and get back a string representation of that integer.thanks for your help :)
On 10/12/2012 at 06:00, xxxxxxxx wrote:
Well, it's technically possible, but you could end up with multiple symbol-names. You'd
need a basecase for the symbol-detection, e.g. when you only want to reach
plugin-symbols, you could use a regular expression like this:import re import c4d plugExpr = re.compile('[A-Z]\w+') def find_keys(dct, value, filter=lambda x: True) : for k, v in dct.iteritems() : if v == value and filter(k) : yield k symbols = find_keys(vars(c4d), c4d.Obase, plugExpr.match) for k in symbols: print k print '-' * 30
Best,
Niklas
On 10/12/2012 at 08:10, xxxxxxxx wrote:
i do not want to sound ungrateful, but if i have understood your example correctly, you suggest
serializing the class into a dictionary and then poke with a regEx in the remains ? i have tried your
example with with Olight and it works for the plugin id as you said, but the returned bc content
was utter nonsense.i was so naive to believe, that there might be a less painfull way to do this :) isn't the symbol
cache file just a cached version of all header files to do this translation , or am i worng ?
