Obtimizing - making a script fast - stopwatch
On 22/11/2012 at 23:49, xxxxxxxx wrote:
Hi everyone,
I have a working script deleting a lot off tags of several mio (yes your read right Millions) objects, but need to optimize the coding.
I want to code a stopwatch at start and end of the code so i can measure my improvements in code - how do i do that?
Also what can I do to make my script faster (stripping all undo code?)
kind regards
mogh
On 23/11/2012 at 00:07, xxxxxxxx wrote:
Hi mogh,
I want to code a stopwatch at start and end of the code so i can measure my improvements in code - how do i do that?You can call GeGetTimer() to measure the execution time of your code. See the code in this post.
Yes, you could try removing your undo code.
On 23/11/2012 at 06:17, xxxxxxxx wrote:
Just had this idea, but it comes with a little more code than I had expected. However, maybe you can find use for it.
# Copyright (C) 2012, Niklas Rosenstein # Licensed under the GNU General Public License import time class Measure(object) : """ This class implements measuring the time of code execution. It also comes with an implementation of the `with` interface. >>> width Measure() as t: ... time_heavy_stuff() ... >>> print t.delta() """ def __init__(self) : super(Measure, self).__init__() self._start = -1 self._delta = -1 def __enter__(self) : self.start() return self def __exit__(self, exc_type, exc_value, exc_tb) : self.stop() def start(self) : self._delta = -1 self._start = time.time() def stop(self) : if self._start < 0: raise RuntimeError('measuring must have been started before.') self._delta = time.time() - self._start self._start = -1 return self._delta def current(self) : if self._start < 0: raise RuntimeError('measuring must have been started before.') return time.time() - self._start def delta(self) : if self._delta < 0: raise RuntimeError('measurement has not been stopped since the ' 'last start.') return self._delta def reset(self) : self._start = -1 self._delta = -1 def main() : with Measure() as t: time.sleep(0.5) print t.delta() main()
On 24/11/2012 at 16:45, xxxxxxxx wrote:
There are a few good tips at the French forum here:
http://frenchcinema4d.fr/showthread.php?75224-Optimisation-en-Python
And yes, for very large set ups, skipping the Undo totally can help - a lot-
for speed in that your ram isn't filled with undos.For some of my PLA scripts/plugins calculating 10s of thausands points per frame
I simply set the main undo to minimum (1) while they are running, resettings
the main undo after they're done.Cheers
Lennart
