Unicode characters
On 19/11/2012 at 07:07, xxxxxxxx wrote:
How to display unicode UTF-8 characters in a menu field?
E.g. I want to display "\u00C5land (Finland)", which display a capital A with a small 0 above it.I have added # coding: UTF-8 to my python code, but nothing happens.
On 19/11/2012 at 09:24, xxxxxxxx wrote:
In Python, you just need to put 'u' before the string literal: u"\u00C5land (Finland)". Strings in CINEMA fully use Unicode characters.
On 19/11/2012 at 10:39, xxxxxxxx wrote:
Thanks.
As always a clear and fast answer!
On 20/11/2012 at 04:24, xxxxxxxx wrote:
Sorry, not yet completely clear.
The following works:
self.AddChild(MY_1SELCONTINENT, CUSTOM, u"\u00C5land (Finland)")This works too:
finland = u"\u00C5land (Finland)"
self.AddChild(MY_1SELCONTINENT, CUSTOM, finland)This, of course, does not work:
self.AddChild(MY_1SELCONTINENT, CUSTOM, ufinland)What I want.
I read in all variables, for example finland = "\u00C5land (Finland)"
How to display this in my GUI?
On 20/11/2012 at 05:51, xxxxxxxx wrote:
self.AddChild(MY_1SELCONTINENT, CUSTOM, ufinland)How do you read ufinland string variable? I think you could use unicode() Python built-in function.
EDIT: Ok, I see you have finland but adding 'u' before doesn't do anything because it only works with string literals. ufinland is a new variable. So you should call unicode(finland) instead.
On 20/11/2012 at 08:34, xxxxxxxx wrote:
Sorry, that does not work.
self.AddChild(MY_1SELCONTINENT, CUSTOM, unicode(finland))It display in the field: \u00C5land (Finland)
On 20/11/2012 at 10:00, xxxxxxxx wrote:
Do you read Unicode strings from a file? You should then decode them to utf-8:
input = open('unicode.txt') finland = input.read() print finland.decode('utf8')
On 20/11/2012 at 13:27, xxxxxxxx wrote:
I tried following script, but it does not work it still displays:"\u00C5land (Finland)" and not the first unicode character.
coding: UTF-8
from c4d import guiunicode.txt contains one line:
def main() :
print "finland utf8: ", finland.decode('utf8')
gui.MessageDialog(finland)if __name__=='__main__':
This is because the unicode file should contain "Ã…land (Finland)", not "\u00C5land (Finland)".
Here's the code I used:# coding: UTF-8 # If you specify UTF-8 encoding, you then don't need to replace Ã… by \u00C5 in your code # See string literal below import c4d from c4d import gui def WriteUnicode() : utf8_string = u"Ã…land (Finland)".encode('utf8') output = open('unicode.txt', 'w') output.write(utf8_string) output.close() def ReadUnicode() : input = open('unicode.txt') utf8_string = input.read() print utf8_string.decode('utf8') def main() : WriteUnicode() ReadUnicode() if __name__=='__main__': main()
On 21/11/2012 at 02:08, xxxxxxxx wrote:
Ok, clear.
However, the input I read from the files uses "\u00C5land (Finland)"
I use the Cinema 4d file \CINEMA 4D R13\modules\advanced render\sky\res\cities.csv
So, how to read that file and display it properly?
Ok, clear.
So, how to read that file and display it properly?Ok, I finally found the solution
We have to decode the string with unicode_escape codec to produce a string that is suitable as raw Unicode literal in Python source code (u'' does this directly with literals).
Here's the code:finland = "\u00C5land (Finland)" print finland # Stored as '\\u00C5land' (double escape) print finland.decode('unicode_escape')
And this code is the same than:
finland = u"\u00C5land (Finland)" print finland
On 21/11/2012 at 07:26, xxxxxxxx wrote:
Thank you very much.
Appreciate the patience and willing to solve it.
