On 13/11/2012 at 15:35, xxxxxxxx wrote:
Hi I'm new to the Forum, looking for a script / plugin that will could import 1000 ai files (splines) into a single C4D project file / and or a way of sequencing them a timeline like Flash / Ae would.
Any ideas would be appreciated. Otherwise will have to do manually. Want to start learning python when I get some free time...
Cheers!
Dan
On 13/11/2012 at 16:00, xxxxxxxx wrote:
If the splines are numbered and ai vers 8 or lower ( so Cinema can read them) you can use the "Xref_xPLAY" preset found in the SteadyBAKE tools found at my site : www.tcastudios.com -> files.
A more manual option is to drag them all in from within the Content Browser. Then you can use a simpler expression to only show/activate the spline corresponding to the frame you need.
Cheers Lennart
On 14/11/2012 at 16:01, xxxxxxxx wrote:
Brilliant. Got it working... Thanks Lennart your a star!
