CustomData converted to GeData
On 29/10/2012 at 15:02, xxxxxxxx wrote:
Cinema 4D Version: 13
Platform: Mac ;
Hello all.I've got a question that seems really noobish, but I can't figure out how to do it. I'm making a material with a proximal shader, and I want to add the objects that are created in a loop to the object field of it.
BaseMaterial *mat = BaseMaterial::Alloc(Mmaterial); BaseShader *shader; InExcludeData *inex; //Loop stuff inex->InsertObject(obj, NULL);// the new object to the inexclude //Loop stuff ends GeData gedataInexclude; //here's where I'm having trouble I need to convert an Inexclude to a GeData and I can't figure it out. shader->SetParameter(1015, gedataInexclude, DESCFLAGS_SET_PARAM_SET);//SLA_PROXIMAL_OBJECTS I know I shouldn't do this part like this my my project won't load the res file mat->SetParameter(MATERIAL_ALPHA_SHADER,shader,DESCFLAGS_SET_PARAM_SET); mat->InsertShader(shader, NULL); doc->InsertMaterial(mat);
So I'm stuck on converting the Inexclude to the GeData so I can use it in the SetParameter. Here's what I've been trying to use:
GeData* gedataInexclude; gedataInexclude->SetCustomDataType(inex,CUSTOMDATATYPE_INEXCLUDE_LIST);
I keep getting errors that there's npo matching function calls and such. I think the problem is I don't understand what SetCustomDataType is looking for.
Any help would be great, thanks in advance!
Dan(edit: fixed typo in title)
On 30/10/2012 at 02:42, xxxxxxxx wrote:
I think you should just swap the 2 parameters of calling SetCustomDataType(). The custom data type ID is expected first, then the custom data value.
On 30/10/2012 at 09:24, xxxxxxxx wrote:
Hi Yannick, thanks for the help, but that didn't work.
I switch it from :
InExcludeData *inex2; GeData *gedataInexclude; //here's where I'm having trouble I need to convert an Inexclude to a GeData and I can't figure it out. gedataInexclude->SetCustomDataType(inex2 , CUSTOMDATATYPE_INEXCLUDE_LIST);
To:
InExcludeData *inex2; GeData *gedataInexclude; //here's where I'm having trouble I need to convert an Inexclude to a GeData and I can't figure it out. gedataInexclude->SetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST,inex2);
And I'm getting this error. " error: no matching function for call to 'GeData::SetCustomDataType(int, InExcludeData*&)'note: candidates are: void GeData::SetCustomDataType(LONG, const CustomDataType&)"
Do I need to covert inex2 from and InExcludeData to a CustomDataType or something? I've tried that ways I know of and those haven't worked.
Thanks for the help.
Dan
On 30/10/2012 at 10:13, xxxxxxxx wrote:
Hi Dan,
CustomDataType is a parent class of InExcludeData but SetCustomDataType() expects a const value so we have to explicitly cast it.
See the trick here: https://plugincafe.maxon.net/topic/4438/4102_problem-by-saving-data&PID=16747#16747
On 30/10/2012 at 12:14, xxxxxxxx wrote:
Thanks again, Yannick! I thought I had tried that already but I guess not. One more question if it's not to much trouble. Now that I've assigned the inexclude to the shader I need to assign the shader to the material.
I saw Scott's thread about it here, https://plugincafe.maxon.net/topic/5689/5725_how-to-get-at-shader-options But he uses the basecontainer to set the parameter and we aren't supposed to do that now correct? So how would it be done with SetParameter? It's not a CustomDataType, I think, so it can't be done the same way as the Inexclude, right?
Dan
Edit: In a related but separate topic, I have a Link description element and I'm trying to get the object out of it. My current code:
GeData objtemp; op->GetParameter(DescLevel(LINKER), objtemp, DESCFLAGS_GET_PARAM_GET); BaseObject* obj = (BaseObject* )objtemp.GetLink(GetActiveDocument());
This code does cause a crash but it always returns NULL regardless of if there's an object in the link field or not. Thanks for any possible help.
On 31/10/2012 at 02:57, xxxxxxxx wrote:
I think you should call GetParameter() with DESCFLAGS_GET_0 instead of DESCFLAGS_GET_PARAM_GET.
I don't understand, what do you want to do?
On 31/10/2012 at 09:06, xxxxxxxx wrote:
Thanks Yannick, that worked perfectly.
Sorry about being unclear. I want to assign a shader to the texture field of a material, specifically around the Alpha channel. In that thread Scott does it like this:
BaseContainer *data = mat->GetDataInstance(); // Get the material's container BaseShader *shd = BaseShader::Alloc(Xsimplenoise); // Creates simple noise instance....For other types(fresnel,etc..). Look up "enum Xbase" in the SDK if(!shd) return FALSE; data->SetLink(MATERIAL_COLOR_SHADER, shd); // Adds simple noise to the color channel in memory only
But isn't using the base container to modify and object bad form? Here's my current code:
shader->SetParameter(1015, tempinex, DESCFLAGS_SET_0);//SLA_PROXIMAL_OBJECTS //Something here to convert a baseshader to gedata mat->SetParameter(MATERIAL_ALPHA_SHADER,gedatashader,DESCFLAGS_SET_0);
It's not a CustomDataType and GeData doesn't have a method for converting it so I'm rather lost right now.
Thanks!
Dan
On 01/11/2012 at 02:20, xxxxxxxx wrote:
Hi Dan,
Material channel's shader are shader link. You can see in Scott's code that he calls SetLink() to set the container value.
So we have to construct the GeData with a BaseLink.Here's how I would create and assign a noise shader to the alpha channel's shader of a material:
BaseShader *shd = BaseShader::Alloc(Xsimplenoise); if (!shd) return FALSE; BaseMaterial *mat = doc->GetFirstMaterial(); if (!mat) return FALSE; AutoAlloc<BaseLink> link; GeData data; link->SetLink(shd); data.SetBaseLink(link); if (mat->SetParameter(MATERIAL_ALPHA_SHADER, data, DESCFLAGS_SET_0)) { mat->InsertShader(shd, NULL); mat->Message(MSG_UPDATE); mat->Update(TRUE, TRUE); EventAdd(); }
On 02/11/2012 at 09:39, xxxxxxxx wrote:
Would one of you guys please post the code to load an object into the proximal's object list?
I tried to use the casting code on that link Yannick posted. But I can't get it right.Here's a code example that will create a new material with a proximal shader in the color channel.
Everything works except the part where I'm trying to load the first object in the OM into the proximal's object list.#include "..\..\..\..\resource\modules\sla\res\description\xslaproximal.h" #include "customgui_inexclude.h" BaseMaterial *mat = BaseMaterial::Alloc(Mmaterial); //Generate a new material and assign a variable to it if(!mat) return TRUE; //Error handling BaseContainer *data = mat->GetDataInstance(); //Get the material's container BaseShader *shd = BaseShader::Alloc(Xproximal); //Creates a proximal instance. Look up "Enum Xbase" in the SDK for others if(!shd) return FALSE; data->SetLink(MATERIAL_COLOR_SHADER, shd); //Adds proximal the color channel in memory only mat->InsertShader(shd, NULL); //Inserts the shader into the material's color channel from memory doc->InsertMaterial(mat); //Adds the new material to the material Manager from memory ((Material* )mat)->SetChannelState(CHANNEL_COLOR, TRUE); //Enables the channel..not usually needed for the color channel // This section changes the proximal's attributes GeData d; //A container that holds the data gotten from GetParameter() below shd->GetParameter(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS), d, DESCFLAGS_GET_0); //Get the Include SubObjects attribute and store the value in "d" shd->SetParameter(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS), TRUE, DESCFLAGS_SET_0); //Enable Include Subobjects option ///////////////////////////////////// This part is wrong and crashes C4D! ////////////////////////////////////////////////// BaseObject *obj = doc->GetFirstObject(); //The object that will be put into the proximal's InExclude list if(!obj) return FALSE; InExcludeData *objList = (InExcludeData* )data->GetCustomDataType(SLA_PROXIMAL_OBJECTS, CUSTOMDATATYPE_INEXCLUDE_LIST);// <---- Wrong!! objList->InsertObject(obj, DESCFLAGS_SET_0); ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////// shd->Message(MSG_UPDATE); //Update the shader changes EventAdd(); mat->Message(MSG_UPDATE); //Update the material changes mat->Update(TRUE, TRUE); //Update the material's icon
Thanks,
On 05/11/2012 at 06:15, xxxxxxxx wrote:
Hi Scott,
In yourcode, data is the material's container, not Proximal shader's container.
We have also to carefully build the description IDs to get the parameters: you're not setting SLA_PROXIMAL_INCLUDE_SUBOBJECTS as expected.Using GetParameter()/SetParameter() is the way to go to access, modify then assign in/exclude lists:
GeData d; DescID id; id = DescID(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS, DTYPE_BOOL, 0)); shd->SetParameter(id, TRUE, DESCFLAGS_SET_0); // Enable Include Subobjects option BaseObject *obj = doc->GetFirstObject(); if (!obj) return FALSE; id = DescID(DescLevel(SLA_PROXIMAL_OBJECTS, CUSTOMDATATYPE_INEXCLUDE_LIST, 0)); if (shd->GetParameter(id, d, DESCFLAGS_GET_0)) // Get proximal objects list { InExcludeData * objList = (InExcludeData* )d.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST); if (!objList) return FALSE; objList->InsertObject(obj, 0); shd->SetParameter(id, d, DESCFLAGS_SET_0); // Set the modified objects list back into the parameters }
On 05/11/2012 at 09:54, xxxxxxxx wrote:
Thank You Yannick.
In case anyone needs it.
Here's a working example of using a GeDialog plugin to create a new material with a proximal shader in the color channel.
Then it loads the selected object into the proximal's In/Ex list:#include "..\..\..\..\resource\modules\sla\res\description\xslaproximal.h" #include "customgui_inexclude.h" BaseObject *obj = doc->GetActiveObject(); //The object we will automatically add to the proximal's In/Ex list if (!obj) return FALSE; //If no object is selected..There's no point in making a new material..So we end it all right here BaseMaterial *mat = BaseMaterial::Alloc(Mmaterial);//Generate a new material and assign a variable to it if(!mat) return TRUE; //Error handling BaseContainer *data = mat->GetDataInstance(); //Get the material's container BaseShader *shd = BaseShader::Alloc(Xproximal); //Creates a proximal instance. Look up "Enum Xbase" in the SDK for others if(!shd) return FALSE; data->SetLink(MATERIAL_COLOR_SHADER, shd); //Adds proximal the color channel in memory only mat->InsertShader(shd, NULL); //Inserts the shader into the material's color channel from memory doc->InsertMaterial(mat); //Adds the new material to the material Manager from memory ((Material* )mat)->SetChannelState(CHANNEL_COLOR, TRUE); //Enables the channel..not usually needed for the color channel GeData d; //A container similar to a BaseContainer DescriptionCommand dc; //In/Ex lists are a descriptions. So we need to store it in this type of variable //DescID id; //Only needed if "id" is not already included in the Command() function's parameters //Alternative way to enable some of the non-description based options inside the proximal shader's attributes //shd->GetParameter(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS), d, DESCFLAGS_GET_0); //Get the Include SubObjects attribute and store the value in "d" //shd->SetParameter(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS), TRUE, DESCFLAGS_SET_0);//Enable Include Subobjects option dc.id = DescID(DescLevel(SLA_PROXIMAL_INCLUDE_SUBOBJECTS, DTYPE_BOOL, 0)); //Get the "Include SubObjects" attribute and store the value in "dc.id" variable shd->SetParameter(dc.id, TRUE, DESCFLAGS_SET_0); //Enable Include SubObjects option dc.id = DescID(DescLevel(SLA_PROXIMAL_OBJECTS, CUSTOMDATATYPE_INEXCLUDE_LIST, 0)); //Get proximal object's list of objects and store it in the dc.id variable if (shd->GetParameter(dc.id, d, DESCFLAGS_GET_0)) //If the list exists<---Just for error checking { //GePrint("Found the Object List"); InExcludeData *objList = (InExcludeData* )d.GetCustomDataType(CUSTOMDATATYPE_INEXCLUDE_LIST); //Create an In/Ex list variable and store it in the "d" container if (!objList) return FALSE; objList->InsertObject(obj, 0); //Insert the object into the proximal's In/Ex list shd->SetParameter(dc.id, d, DESCFLAGS_SET_0); //Update the modified parameters LONG count = objList->GetObjectCount(); //Get the number of object's in the In/Ex list GePrint(LongToString(count)); } shd->Message(MSG_UPDATE); //Update the changes made to the shader mat->Message(MSG_UPDATE); //Update the changes made to the material mat->Update(TRUE, TRUE); //Refresh the materials displayed icon EventAdd();
On 08/11/2012 at 11:01, xxxxxxxx wrote:
Thanks a ton for all the help both of you! I'd post my finished code, but Scott showed it so much better then I could.
Thanks!
Dan
