delay 1 frame when inserting new object
On 23/10/2012 at 20:01, xxxxxxxx wrote:
Cinema 4D Version: 13
Platform:
i'm kinda new to sdk
here's what i did to create a simple polygon just by clicking the icon in the plugin menuBool MyPlugin::Execute(BaseDocument *doc)
BaseObject* mine = NULL;
mine = BaseObject::Alloc( Opolygon );
mine->SetName("MyPolygon");
doc->InsertObject( mine , NULL , NULL );
doc->AddUndo( UNDOTYPE_NEW, mine );
doc->Message(MSG_UPDATE);
return true;
}problem is ...after i click...i need to press any where to update the document...help please :)
On 23/10/2012 at 21:54, xxxxxxxx wrote:
mine->Message(MSG_UPDATE); // Not doc->! EventAdd(); // Let C4D know that it needs to update its managers
Also note that you should always check memory allocations/class instance creation:
Bool MyPlugin::Execute(BaseDocument *doc) { BaseObject* mine = BaseObject::Alloc( Opolygon ); if (!mine) return false; mine->SetName("MyPolygon"); doc->InsertObject( mine , NULL , NULL ); doc->AddUndo( UNDOTYPE_NEW, mine ); mine->Message(MSG_UPDATE); EventAdd(); return true; }
Finally, remember that you will need to cast the BaseObject into a PolygonObject in order to add and manipulate vertices and polygons using the latter's methods. Use PolygonObject* pmine = ToPoly(mine) to do that (for instance).
On 24/10/2012 at 00:19, xxxxxxxx wrote:
well thanks alot for this :D
now for the next fail ...
if (!mine) return false;mine->SetName("MyPolygon"); doc->InsertObject( mine , NULL , NULL ); doc->AddUndo( UNDOTYPE_NEW, mine ); mine->Message(MSG_UPDATE); EventAdd(); PolygonObject\* pmine = ToPoly(mine); pmine->Alloc(100,0); Vector \*padr; padr = pmine->GetPointW(); int i; for (i=0;i<100;i++) padr _= Vector(0,0,0); pmine->Message(MSG_UPDATE); EventAdd(); return true;
program always crashes when i execute ....I'm sure im missing something ...
On 24/10/2012 at 01:33, xxxxxxxx wrote:
Alloc() is a static method that returns a newly allocated PolygonObject, but as you already have a PolygonObject (pmine) you should call ResizeObject() instead:
pmine->ResizeObject(100,0);
Also in the for-loop you have to assign points position with [] or pointer arithmetic:
for (LONG i=0;i<100;i++) padr[i] = Vector(0,0,0);
or
for (LONG i=0;i<100;i++,padr++) *padr = Vector(0,0,0);
On 24/10/2012 at 01:52, xxxxxxxx wrote:
thanks alot for the help :)
it worked...by the way....did i made any code mistakes ( i mean after the loop with msg update and c4d event)
On 25/10/2012 at 05:38, xxxxxxxx wrote:
well ...it worked :D
but now i want to animate the points by giving them an array of vectors each frame ...here's the code...and it crashes always...
if (!mine) return false;mine->SetName("MyPolygon"); doc->InsertObject( mine , NULL , NULL ); doc->AddUndo( UNDOTYPE_NEW, mine ); mine->Message(MSG_UPDATE); EventAdd(); PolygonObject\* pmine = ToPoly(mine); pmine->ResizeObject(100,0); Vector \*padr; padr = pmine->GetPointW(); int i; for (i=0;i<100;i++){ padr _= Vector(0,0,0); }; pmine->Message(MSG_UPDATE); EventAdd(); BaseTime time = doc->GetTime(); Real fps = doc->GetFps(); Real frame = time.GetFrame(fps); CTrack \*MyTrack = mine->FindCTrack(DescID(DescLevel(CTpla,DTYPE_LONG,0))); CCurve \*MyCurve = MyTrack->GetCurve(); CKey \*Key1 = MyCurve->AddKey(BaseTime(frame,fps)); //GePrint(RealToString(frame)); //GePrint(RealToString(fps)); return true;
another question ( as i'm still new :D) .... i'm using the cinema4d sdk solution in vs 2010 ...win 8 64 bit (win 7 64 bit compiler) ... what should i add in c++ general properties ...linker ..to do debug...
thanks in advance
On 25/10/2012 at 07:22, xxxxxxxx wrote:
Originally posted by xxxxxxxx
_another question ( as i'm still new :D) .... i'm using the cinema4d sdk solution in vs 2010 ...win 8 64 bit (win 7 64 bit compiler) ... what should i add in c++ general properties ...linker ..to do debug...
_To debug a plugin you have to build it in Debug configuration and set CINEMA.exe as the executable for debug session in Configuration properties->Debugging:Command. See also the docs at the Debug Information's page.
On 25/10/2012 at 08:02, xxxxxxxx wrote:
still i need to know why the above code crashes (searched for pla data type...but didn't find any example...so i assumed it's long data type...though i think the fail isn't from data type ...
still i need to know why the above code crashes (searched for pla data type...but didn't find any example...so i assumed it's long data type...though i think the fail isn't from data type ...CTrack *MyTrack = mine->FindCTrack(DescID(DescLevel(CTpla,DTYPE_LONG,0))); CCurve *MyCurve = MyTrack->GetCurve(); CKey *Key1 = MyCurve->AddKey(BaseTime(frame,fps));
The track may be NULL. Have you tested that MyTrack isn't NULL?
You should create a track and insert it with InsertTrackSorted() instead.
On 25/10/2012 at 10:43, xxxxxxxx wrote:
well at least now i know where it fails :D
but the test is false :(
if (!MyTrack){MyTrack = CTrack::Alloc(mine,DescID(DescLevel(CTpla,DTYPE_LONG,0))); if(!MyTrack) return FALSE; mine->InsertTrackSorted(MyTrack); doc->AddUndo( UNDOTYPE_NEW, MyTrack );
On 25/10/2012 at 15:58, xxxxxxxx wrote:
well i tried...and still don't know why it can't Alloc(CTpla) ...here's the code...
doc->AddUndo( UNDOTYPE_NEW, mine );mine->Message(MSG_UPDATE);
EventAdd();PolygonObject* pmine = ToPoly(mine);
pmine->ResizeObject(100,0);Vector *padr;
padr = pmine->GetPointW();int i;
pmine- >Message(MSG_UPDATE);
EventAdd();
BaseTime time = doc- >GetTime();
Real fps = doc- >GetFps();
CTrack *MyTrack = mine->FindCTrack(DescID(DescLevel(CTpla,CUSTOMDATATYPE_PLA,0)));
if (!MyTrack){MyTrack = CTrack::Alloc(mine,DescID(DescLevel(CTpla,CUSTOMDATATYPE_PLA,0)));
doc->AddUndo( UNDOTYPE_NEW, MyTrack );};
CCurve *MyCurve = MyTrack- >GetCurve();
CKey *Key1 = MyCurve- >AddKey(BaseTime(frame,fps));
EventAdd(EVENT_ANIMATE);
return true;
_}edited : changed DTYPE_LONG to _ CUSTOMDATATYPE_PLA
On 26/10/2012 at 05:06, xxxxxxxx wrote:
We can allocate a PLA track with the following DescID:
DescID descID = DescLevel(CTpla, CTpla, 0L);
Anyway, here's a piece of code (mainly taken from Robert Templeton's code in this post) that shows how to animate the points of a PolygonObject:
// Allocate a polygon object with 4 points and 1 polygon PolygonObject *polyObj = PolygonObject::Alloc(4, 1); if (!polyObj) return FALSE; polyObj->SetName("MyPolygon"); doc->InsertObject(polyObj, NULL, NULL); // Get point buffer Vector *dpoints = polyObj->GetPointW(); // Get polygon buffer and initialize it CPolygon *dpolygons = polyObj->GetPolygonW(); dpolygons[0].a = 0; dpolygons[0].b = 1; dpolygons[0].c = 2; dpolygons[0].d = 3; // Update polygon object and document polyObj->Message(MSG_UPDATE); EventAdd(); // Allocate PLA track DescID descID = DescLevel(CTpla, CTpla, 0L); CTrack *track = CTrack::Alloc(polyObj, descID); if (!track) return FALSE; polyObj->InsertTrackSorted(track); // Get track curve to create keys for each frame CCurve *seq = track->GetCurve(); if (!seq) return FALSE; CKey *key = NULL; // Sample Animation at each frame ModelingCommandData mcd; mcd.doc = doc; mcd.op = polyObj; BaseContainer mbc; mbc.SetBool(MDATA_CURRENTSTATETOOBJECT_INHERITANCE, TRUE); mbc.SetBool(MDATA_CURRENTSTATETOOBJECT_KEEPANIMATION, FALSE); mcd.bc = &mbc; mcd.flags = MODELINGCOMMANDFLAGS_0; BaseObject *csto = NULL; PointObject *defd = NULL; LONG pointCount = polyObj->GetPointCount(); LONG pointSize = pointCount*sizeof(Vector); const Vector *spoints = NULL; Vector *points = NULL; BaseTime stime = doc->GetMinTime(); BaseTime etime = doc->GetMaxTime(); Real fps = doc->GetFps(); LONG startf = stime.GetFrame(fps); LONG endf = etime.GetFrame(fps); LONG currentf = 0L; for (; startf <= endf; startf += 1L) { stime = BaseTime::BaseTime(startf, fps); currentf = stime.GetFrame(fps); // Animate document doc->SetTime(stime); doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0); EventAdd(); // Current State to Object if (!SendModelingCommand(MCOMMAND_CURRENTSTATETOOBJECT, mcd)) return FALSE; csto = (BaseObject* )(mcd.result->GetIndex(0)); AtomArray::Free(mcd.result); if (!csto) return FALSE; if (csto->IsInstanceOf(Onull)) defd = ToPoint(csto->GetDown()); else defd = ToPoint(csto); if (!defd) return FALSE; // Add key key = seq->AddKey(stime); if (!key) { BaseObject::Free(csto); return FALSE; } // Add PLA key data spoints = defd->GetPointR(); if (!spoints) { BaseObject::Free(csto); break; } // Modify points for animation points = defd->GetPointW(); if (!points) return FALSE; points[0] = Vector(-1000*currentf,0,-1000*currentf); points[1] = Vector(-1000*currentf,0,1000*currentf); points[2] = Vector(1000*currentf,0,1000*currentf); points[3] = Vector(1000*currentf,0,-1000*currentf); // Copy source points (read) to original polygon object points (write) CopyMem(spoints, dpoints, pointSize); // Fill key with default values if (!track->FillKey(doc, polyObj, key)) { BaseObject::Free(csto); return FALSE; } // Do not forgot to free CSTO command's object BaseObject::Free(csto); } doc->SetTime(doc->GetMinTime());
On 26/10/2012 at 05:23, xxxxxxxx wrote:
wow :)
u made my day :D
thanks alot for the help ....keep the good support ^_^
On 27/10/2012 at 02:18, xxxxxxxx wrote:
well i've found that size of vector is 24 bytes...this means vector data is considered (double)?which is real in c4d library
On 27/10/2012 at 02:19, xxxxxxxx wrote:
another question...does points have rotation? i've found in the sdk there's position and tangent tags...but when i try to rotate points it doesn't seem to rotate in viewport(resets gizmo rotation each time)
On 31/10/2012 at 08:58, xxxxxxxx wrote:
well i've solved the problems and found answers :D
just when i was reading the posts i noticed everytime i type a for loop and type the array brackets it doesnt appear (just for readers to notice that it's an iteration over array index)
