On 21/10/2012 at 07:03, xxxxxxxx wrote:
--------- Hey Guys,
I am working on an objectdata-plugin. I create several objects (NURBS) in GetVirtualObjects and I want to make them transparent. So I do something like this:
BaseContainer *bc = obj->GetDataInstance(); bc->SetLong(ID_BASEOBJECT_VISIBILITY_EDITOR, editor); bc->SetLong(ID_BASEOBJECT_VISIBILITY_RENDER, render); bc->SetBool(ID_BASEOBJECT_XRAY, xray);
But x-ray does not get set. Any idea why?
On 21/10/2012 at 15:15, xxxxxxxx wrote:
The only place it seems to work is inside of the Draw() function.
DRAWRESULT MyObject::Draw(BaseObject *op, DRAWPASS drawpass, BaseDraw *bd, BaseDrawHelp *bh) { //code that draws the object here .... //Get the state of the xray option GeData d; op->GetParameter(DescID(ID_BASEOBJECT_XRAY), d, DESCFLAGS_GET_0); LONG xstate = d.GetLong(); GePrint(LongToString(xstate)); //Enable the Xray option op->SetParameter(DescID(ID_BASEOBJECT_XRAY), GeData(TRUE), DESCFLAGS_SET_0); EventAdd(); return DRAWRESULT_OK; }
On 21/10/2012 at 16:18, xxxxxxxx wrote:
Hey Scott,
Thank you for your replay. It works but the problem is, that the hole object would be transparent. I only want a special object.
I get an other method, but here I must convert my NURB object and that is not very fine...
bd->DrawPolygonObject(bh, res, DRAWOBJECT_XRAY_ON, op, green);
On 22/10/2012 at 01:46, xxxxxxxx wrote:
Please check the BaseObject::SetColorProperties() function. It's used to set object colors and X-Ray.
On 22/10/2012 at 06:13, xxxxxxxx wrote:
Does not work.
ObjectColorProperties ocp; ocp.usecolor = ID_BASEOBJECT_USECOLOR_ALWAYS; ocp.xray = TRUE; ocp.color = Vector(0.0,1.0,0.0); //green obj->SetColorProperties(&ocp);
On 22/10/2012 at 06:29, xxxxxxxx wrote:
You're setting it on the object you're generating. Set it on the generator object itself and it will work. I.e.:
BaseObject* MyObjectDataPlugin::GetVirtualObjects(BaseObject *op, HierarchyHelp *hh) { //.... do other stuff ObjectColorProperties ocp; ocp.usecolor = ID_BASEOBJECT_USECOLOR_ALWAYS; ocp.xray = TRUE; ocp.color = Vector(0.0,1.0,0.0); //green op->SetColorProperties(&ocp;); // <------ uses 'op' not your generated object }
On 22/10/2012 at 09:46, xxxxxxxx wrote:
Hey spedler,
Thank you but I want to use it on an object I generate and not on a the hole generator. Only a part of it.
On 18/04/2013 at 08:56, xxxxxxxx wrote:
If anyone run into the same problem.. you have to set the OBJECT_USECACHECOLOR flag when registering the object to avoid that the color properties get overwritten by the generator.
