GetVirtualObjects - BaseObj to PointObj
On 19/10/2012 at 17:44, xxxxxxxx wrote:
Hey Guys,
I creating a ObjectData-Plugin. Why is this not working?
def GetVirtualObjects(self, op, hierarchyhelp) : spline = c4d.BaseObject(c4d.Osplinerectangle); w = c4d.utils.SendModelingCommand(command = c4d.MCOMMAND_MAKEEDITABLE, list = [spline]) print(w) return spline
I get False back... :(
On 20/10/2012 at 04:00, xxxxxxxx wrote:
I use now:
spline = op.GetAndCheckHierarchyClone(hh, spline, c4d.HIERARCHYCLONEFLAGS_ASLINE, False)["clone"]
And this is not working. I cannot set XRAY in virtual objects... :(
def GetVirtualObjects(self, op, hh) : cube = c4d.BaseObject(c4d.Ocube) cube[c4d.ID_BASEOBJECT_XRAY] = 1 return cube
And is it possible to change the String/Name (Dialog?) of an description-element if I use the res folder-system?
Help me please!
On 20/10/2012 at 11:22, xxxxxxxx wrote:
I imagine using CSTO might be better as you'll return
an object based on a copy.
Make Editable "kills" the source and thus are prone to
not be alive.The xray issue I can't tell, but I guess that can only
be set to the actuall result, that is the Generator itself.Cheers
Lennartimport c4d from c4d import utils as u def main() : spline = c4d.BaseObject(c4d.Osplinerectangle) w = u.SendModelingCommand(command = c4d.MCOMMAND_CURRENTSTATETOOBJECT, list = [spline], doc = op.GetDocument()) return w[0]
On 20/10/2012 at 16:08, xxxxxxxx wrote:
Hey Lennart,
Thank you for your replay.
The xray problem is very bitter. Why does editor/render on/off working but not this. :(
On 23/10/2012 at 00:38, xxxxxxxx wrote:
Did you try setting the Xray option on "op" instead of on your virtual object?
