Enable Tag upon selected?
On 15/10/2012 at 07:05, xxxxxxxx wrote:
Is there a way to enable the python tag only, when the object that the tag sits on, is selected?
On 15/10/2012 at 07:40, xxxxxxxx wrote:
Hi hypoly,
in the Tags' code, you can just check if the object is selected. And if it is, you can execute the rest of the code.
def main() :
  og = op.GetOrigin()
  if not og.GetBit(c4d.BIT_ACTIVE) :
  # Rest of the code
Note that the rest of the code is also evaluated if the object is one of multiple selected objects. If you want to ensure it is the only active object, you can do:
def main() :
  og = op.GetOrigin()
  if og != doc.GetActiveObject() :
  # Rest of the code
Niklas
On 15/10/2012 at 07:49, xxxxxxxx wrote:
Thats great, thanks Niklas!
