Python Integration?
On 28/09/2012 at 10:44, xxxxxxxx wrote:
Cinema 4D Version:   13+
okay I can load and execute a python script but is there a way to extent the language with global variables or similar (just like for the Coffee engine)?
Thanks in advance
On 28/09/2012 at 11:19, xxxxxxxx wrote:
lib_python is not documented unfortuneately. :( Could you please post the code you use to execute a script? :)
Thanks,
-Niklas
On 30/09/2012 at 08:13, xxxxxxxx wrote:
I have no code I only found the example in the docs. Look out for ID_PYTHONSCRIPT.
I didn't know there was a pylib already. I check that, thanks for the hint. Anyway, at first glance I don't see anything that helps me with my question, so it would be nice if the support could give a direction or info on this.
On 12/02/2013 at 09:26, xxxxxxxx wrote:
Hi Samir,
Here's a small code example that shows how to add a global constant to c4d module:
void RegisterConstant()
    GePythonGIL gil; // gil must be created
    PythonLibrary pylib;
    _PyObject* mod = pylib.GetModule("c4d");
    if (mod)
        pylib.InitConstant(mod, "constant", 30)
Bool PluginMessage(id, data)
    switch (id)
        case C4DPL_PYINITTYPES:
        RegisterConstant();
        break;
    return true;
On 12/02/2013 at 11:23, xxxxxxxx wrote:
Thanks Yannick!
