On 25/09/2012 at 17:03, xxxxxxxx wrote:
User Information: Cinema 4D Version: 14 Platform: Windows ; Language(s) : C++ ;
--------- Hey everyone,
I am using
ModelingCommandData mcd2; BaseContainer bc2; bc2.SetBool(MDATA_SUBDIVIDE_HYPER, FALSE); bc2.SetReal(MDATA_SUBDIVIDE_SUB, 1); bc2.SetReal(MDATA_SUBDIVIDE_ANGLE, pi); mcd2.bc = &bc2; mcd2.op = obj; mcd2.mode = MODELINGCOMMANDMODE_ALL; mcd2.doc = doc; if(SendModelingCommand(MCOMMAND_SUBDIVIDE, mcd2)){}
I was wondering if it is possible to access the new points that were created as a result of this? I don't want to original points that already existed, just the new ones that were created. Is this possible?
Thanks,
Shawn
On 25/09/2012 at 17:17, xxxxxxxx wrote:
Howdy,
I believe most of the time when new points are added like that, they're simply added to the end of the points array. For example if the original cube has 8 points { indices 0 through 7}, the first new point after subdividing would be at index 8.
You can test that in Cinema 4D by subdividing a cube and looking in the Structure Manager. You'll notice that the first 8 points are still at the original cube's corners.
Adios, Cactus Dan
On 25/09/2012 at 17:28, xxxxxxxx wrote:
YES! Awesome .. thanks Dan!
On 25/09/2012 at 17:34, xxxxxxxx wrote:
You're welcome.
There are some tools that don't simply add new points to the end. I've encountered that before but I can't remember which tools they were.
