On 23/09/2012 at 04:06, xxxxxxxx wrote:
I currently have this:
But would like this:
Any ideas would be appreciated.
CONTAINER SweepTaper { NAME SweepTaper; INCLUDE Obase; GROUP TAPER { COLUMNS 2; BOOL START {} REAL STARTSLIDER { CUSTOMGUI REALSLIDER; MIN 0.0; MINSLIDER 0.0; MAX 50.0; MAXSLIDER 50.0; STEP 0.1; UNIT PERCENT; } BOOL END {} REAL ENDSLIDER { CUSTOMGUI REALSLIDER; MIN 0.0; MINSLIDER 0.0; MAX 50.0; MAXSLIDER 50.0; STEP 0.1; UNIT PERCENT; } REAL GROWTHSCALE { CUSTOMGUI REALSLIDER; MIN 0.0; MINSLIDER 0.0; MAX 100.0; MAXSLIDER 100.0; STEP 1; UNIT PERCENT; } } }
On 23/09/2012 at 04:54, xxxxxxxx wrote:
Seperate the elements by unnamed groups.
// ... GROUP { COLUMNS 2; // ... } GROUP { // ... } // ...
You could also leave out the latter group.
-Niklas
On 23/09/2012 at 06:02, xxxxxxxx wrote:
Thanks Niklas, Did you mean like this? I suspect not as it its coming out wrong.
CONTAINER SweepTaper { NAME SweepTaper; INCLUDE Obase; GROUP TAPER { GROUP { COLUMNS 2; BOOL START {} REAL STARTSLIDER { MIN 0.0; MAX 50.0; STEP 0.1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } } GROUP { BOOL END {} REAL ENDSLIDER { MIN 0.0; MAX 50.0; STEP 0.1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } } REAL GROWTHSCALE { MIN 0.0; MAX 50.0; STEP 1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } } }
On 23/09/2012 at 08:54, xxxxxxxx wrote:
No, I meant this:
CONTAINER SweepTaper { NAME SweepTaper; INCLUDE Obase; GROUP TAPER { GROUP { COLUMNS 2; BOOL START {} REAL STARTSLIDER { MIN 0.0; MAX 50.0; STEP 0.1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } BOOL END {} REAL ENDSLIDER { MIN 0.0; MAX 50.0; STEP 0.1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } } REAL GROWTHSCALE { MIN 0.0; MAX 50.0; STEP 1; UNIT PERCENT; CUSTOMGUI REALSLIDER; } } }
Please note that your symbol-naming does not follow the typical naming conventions. See my post in this thread for more information.
On 23/09/2012 at 09:11, xxxxxxxx wrote:
Thanks Niklas, I will have a read over you post on the naming conventions. Unfortunately this is this the result of the code above. Seems a little tricky to get this to appear correctly.
On 23/09/2012 at 09:37, xxxxxxxx wrote:
Maybe the SCALE_H; flag (for the group with the 4 elements) will fix this issue.
On 23/09/2012 at 09:45, xxxxxxxx wrote:
Yea I tried that before, and just now, with no luck, comes up with reading .res file error now. Darn it.
