Weird Problem
    On 21/09/2012 at 18:27, xxxxxxxx wrote:
    Cinema 4D Version:   14
    Platform:   Windows  ;
    Hey everyone,
    I am getting a strange error that is crashing C4D.
    When I run C4D through the debugger in VS 2010 I get the following exception in the file c4d_objectplugin.cpp.
    the exception happens at line 163 in that file:
    The exception is:
    Unhandled exception at 0x0e3d217a (PXG Elements.cdl) in CINEMA 4D Demo.exe: 0xC0000005: Access violation reading location 0x00000000.
    This is happening even on an object plugin with no new code added to it.  Just an empty skeleton.
    I am not sure why this is happening but any time I try to open any of my object plugins they crash c4d.
    Is this a bug in the API?  or am I doing something wrong?
    Here is the skeleton object code:
    #include "c4d.h"
    #include "c4d_symbols.h"
    #include "myplugin.h"
    //PLUGIN ID
    "INTENTIONALLY REMOVED"
    //CLASS
    class MyPlugin : public ObjectData{
      public:
          //Inherited Methods
          virtual Bool            Init(GeListNode *node);
          virtual Bool            Message(GeListNode *node, LONG type, void *t_data);
          static    NodeData        *Alloc(void) { return gNew MyPlugin; }
          virtual DRAWRESULT        Draw(BaseObject* op, DRAWPASS drawpass, BaseDraw* bd, BaseDrawHelp* bh);
          virtual BaseObject        *GetVirtualObjects(BaseObject* op, HierarchyHelp* hh);
    //Initialize Default Settings
    Bool MyPlugin::Init(GeListNode *node){
      GePrint("INIT");
      return TRUE;
    //Draw Visual Aides
    DRAWRESULT MyPlugin::Draw(BaseObject* op, DRAWPASS drawpass, BaseDraw* bd, BaseDrawHelp* bh)
      GePrint("DRAW");
      return DRAWRESULT_OK;
    //Generate Virtual Objects
    BaseObject *MyPlugin::GetVirtualObjects(BaseObject* op, HierarchyHelp* hh){
      GePrint("GVO");
      return NULL;
    //Checks messages from the plugin
    Bool MyPlugin::Message(GeListNode *node, LONG type, void *t_data){
      GePrint("MSG");
      return TRUE;
    //REGISTER THE PLUGIN
    Bool RegisterMyPlugin(void){
      String name=GeLoadString(IDS_MYPLUGIN); if (!name.Content()) return TRUE;
      return RegisterObjectPlugin(ID_MYPLUGIN, name, OBJECT_GENERATOR, MyPlugin::Alloc,"my_plugin",AutoBitmap("my_plugin.tif"),0);
    Any thoughts as to why this is happening.  It doesn't seem to matter which of my object plugins I try to run ,  it still crashes in R14.
    Thanks,
    Shawn
    On 21/09/2012 at 18:55, xxxxxxxx wrote:
    This is the function that throws the exception:
    Bool ObjectData::MoveHandle( BaseObject *op, BaseObject *undo, const Vector &mouse_pos, LONG hit_id, QUALIFIER qualifier, BaseDraw *bd )
      Matrix mg = op->GetUpMg() * undo->GetMl();
      HandleInfo info;
      ((ObjectData* )undo->GetNodeData())->GetHandle(undo,hit_id,info);
      SetHandle(op,hit_id,info.CalculateNewPosition(bd, mg, mouse_pos),info);
      return TRUE;
    On 25/09/2012 at 11:04, xxxxxxxx wrote:
    Are you sure that
    BaseObject *op
    BaseObject *undo
    BaseDraw *bd
    are not NULL ?
