On 18/09/2012 at 23:31, xxxxxxxx wrote:
Hi guys! I have an area light that I'd like to be set to Object mode and I would like the child to be defined as that object. And, if possible, have a shortcut for this sort of light in the top panel with my other lights.
I understand this can be done using a Python tag but I know nothing about it.
If you could help or at least point me in the right direction where I can learn, I would really appreciate it
Thanks in advance!
On 19/09/2012 at 11:34, xxxxxxxx wrote:
Hello. I think this script will be the button you want, select the objects you want and then when you run it they'll be inserted under a newly created light and put into the objects list.
import c4d from c4d import gui def main() : objs = doc.GetActiveObjects(True) light = c4d.BaseObject(c4d.Olight) light[c4d.LIGHT_TYPE] = 8 #set type to area inexclude = c4d.InExcludeData() #Create and inexclude data to set the light's one too. doc.InsertObject(light)#insert the object into the scene for obj in objs:#if mutliple objects are selected it will insert all of them into the include data inexclude.InsertObject(obj,15) obj.InsertUnder(light) #move the objects under the newly created light light[c4d.LIGHT_EXCLUSION_LIST] = inexclude c4d.EventAdd() if __name__=='__main__': main()
And I think this is the code for a python tag you want:
import c4d #Welcome to the world of Python def main() : obj = op.GetObject()#Get the object that owns the tag children = obj.GetChildren() #Get the children of that object inexclude = c4d.InExcludeData() #Create and inexclude data to set the light's one too. for child in children:#if mutliple objects are selected it will insert all of them into the include data inexclude.InsertObject(child,15) obj[c4d.LIGHT_EXCLUSION_LIST] = inexclude c4d.EventAdd()
Dan
On 20/09/2012 at 04:15, xxxxxxxx wrote:
Hi Dan! Thanks for the reply! What I'm looking for is for the first child to be placed as an object in:
Light Attributes > Details > Object (right under Area Shape);
And where did you learn this coding??
On 20/09/2012 at 09:11, xxxxxxxx wrote:
No problem, I think this is what you want then.
The script:
import c4d from c4d import gui def main() : obj = doc.GetActiveObject()#Gets only the first active object if obj != None: light = c4d.BaseObject(c4d.Olight) light[c4d.LIGHT_TYPE] = 8 #set type to area doc.InsertObject(light)#insert the object into the scene obj.InsertUnder(light) #move the objects under the newly created light light[c4d.LIGHT_AREADETAILS_SHAPE] =6 light[c4d.LIGHT_AREADETAILS_OBJECT] = obj #set the selected object as the object field c4d.EventAdd() if __name__=='__main__': main()
The tag:
import c4d #Welcome to the world of Python def main() : obj = op.GetObject()#Get the object that owns the tag child = obj.GetDown() #Get the first child of that object obj[c4d.LIGHT_AREADETAILS_SHAPE] = 6 #setting area shape to object obj[c4d.LIGHT_AREADETAILS_OBJECT] = child #Set the object field to the child c4d.EventAdd()
I've been doing Python with C4D for a bit now, I started with this tutorial: http://chicagoc4d.com/videos/python/189-introduction-to-python I wouldn't worry about the twitter stuff through. Everyone on the forum has been a huge help as well.
On 21/09/2012 at 02:57, xxxxxxxx wrote:
Dude awesome thanks! Really appreciate the # explanations! Definitely learned something useful here.
Cheers, dude. David
