On 17/09/2012 at 04:21, xxxxxxxx wrote:
hi , it's my very first post here hope experts can help me on how to install numpy library (arrays and math functions ....etc) and pycuda (is it supported to make the gpu do calculations???)
hope any one answer with clarification (i'm not expert yet)
On 17/09/2012 at 07:34, xxxxxxxx wrote:
Salamu Alaykum(Hello) If you will to search over this forum and cgsociety.org, will find Niklas Rosenstein's post(and special tools as pythonbuilder and importfix) about imports. But i use such method as mentioned by Ludovic at http://mgl.scripps.edu/forum/viewtopic.php?p=3180&sid=0d6f2e6cb517da1a6634de90994c5a7f#p3180
On 18/09/2012 at 21:32, xxxxxxxx wrote:
w alikum alsalam brother well i'm trying right now ...will tell you the progress soon
On 20/09/2012 at 12:51, xxxxxxxx wrote:
well i did 2 attempts....
first :
installed numpy on my python 2.6.6 folder in c...then copied the numpy folder to cinema4d user library python package blablabla
error is: Traceback (most recent call last) : File "'Python'", line 2, in <module> File "C:\Users\Mohamed\AppData\Roaming\MAXON\CINEMA 4D R14 Demo_555A13E8\library\python\packages\win32\numpy\__init__.py", line 137, in <module> import add_newdocs File "C:\Users\Mohamed\AppData\Roaming\MAXON\CINEMA 4D R14 Demo_555A13E8\library\python\packages\win32\numpy\add_newdocs.py", line 9, in <module> from numpy.lib import add_newdoc File "C:\Users\Mohamed\AppData\Roaming\MAXON\CINEMA 4D R14 Demo_555A13E8\library\python\packages\win32\numpy\lib\__init__.py", line 4, in <module> from type_check import * File "C:\Users\Mohamed\AppData\Roaming\MAXON\CINEMA 4D R14 Demo_555A13E8\library\python\packages\win32\numpy\lib ype_check.py", line 8, in <module> import numpy.core.numeric as _nx File "C:\Users\Mohamed\AppData\Roaming\MAXON\CINEMA 4D R14 Demo_555A13E8\library\python\packages\win32\numpy\core\__init__.py", line 5, in <module> import multiarray ImportError: DLL load failed: The specified module could not be found.
second attempt : removed all cinema4d internal python..copied the python folder 2.6.6 and renamed it to python 32 framework (same as the one in cinema4d)
and as expected it didn't work cause didn't recognize c4d functions
i think the first problem due to python versions (2.6.6 is a must use ....while c4d uses 2.6.4) any idea how to solve
On 21/09/2012 at 05:20, xxxxxxxx wrote:
any idea how to install that numpy to cinema4d python?
On 21/09/2012 at 09:29, xxxxxxxx wrote:
it works http://imm.io/F89k from sample http://scipy.org/Numpy_Example_List#head-a2c30dcf07b9b3297da2b1d9bc71a0055b4d7bcc
On 21/09/2012 at 11:43, xxxxxxxx wrote:
cool !! tell me what u did to do that or give me (if possible) a compressed .rar version of python 32 framework folder
On 22/09/2012 at 20:09, xxxxxxxx wrote:
well i downloaded the patch ...with numpy ..it worked but i don't know if it's fully function with cinema4d module or not
