Setting SplineData gridlines through code
    On 14/09/2012 at 11:41, xxxxxxxx wrote:
    How can I change, in python, the number of gridlines (vertical or horizontal, it doesn't matter) of a SplineData field?
    I know that I must use:
    SplineCustomGui.SetGridLineCountH(n)
    for setting the number of horizontal lines. But how?!?!
    Rui Batista
    On 14/09/2012 at 12:36, xxxxxxxx wrote:
    If, at least, I knew how to get the SplineCustomGui of my SplineData.
    But that is not clear in the SDK :-(
    If I can't even get the SplineCustomGui of an element, how am I supposed to use SetGridLineCountH(n)?
    On 14/09/2012 at 14:24, xxxxxxxx wrote:
    Damn! I can't even create an instance with:
    customgui=c4d.gui.SplineCustomGui()
    What can we do with this class?!?!?
    Rui Batista
    On 14/09/2012 at 15:52, xxxxxxxx wrote:
    This is exasperating!!!
    How is it that something as simple as changing the number of gridlines of a spline data element proves to be soooooo complicated?!
    If a class is not accessible, why is it in the SDK?
    Rui Batista
    On 14/09/2012 at 16:12, xxxxxxxx wrote:
    I have read this in the C++ SDK:
    Spline data type (CUSTOMDATATYPE_SPLINE) for the SplineCustomGui GUI. Cannot be instantiated directly.
    If it can't be instantiated directly, how can we instantiate it indirectly?
    On 15/09/2012 at 13:33, xxxxxxxx wrote:
    Hello Rui, _
    > > If it can't be instantiated directly, how can we instantiate it indirectly?_
    GeDialog.AddCustomGui() instanciates it internally and returns a reference to the created BaseCustomGui instance. I couldn't find a way, in Python, to retrieve a custom-gui that was instantiated by the dialog-resource loader.
    But afaik you are currently working on an Object plugin. Afaik we are not able to obtain the BaseCustomGui instance from descriptions. I'm sorry but I can not tell you how to do what you want to achive. I'm actually not even sure how to do this in C++. An official statement would be very appreciated!
    -Niklas
    On 16/09/2012 at 00:47, xxxxxxxx wrote:
    +100
    i can't get it too.
    sample code:
    from c4d import gui,storage
    SPG = 1001
    DGR = 1002
    BUTTON_1 = 1003
    class TestSplGui(gui.GeDialog) :
      global spl
      def CreateLayout(self) :
          global spl
          self.AddButton(BUTTON_1, c4d.BFH_LEFT, 150, 15, "Test")
          self.LayoutFlushGroup(1002)
          self.GroupBegin(DGR, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT)
          bc = c4d.BaseContainer()
          bc[c4d.SPLINECONTROL_GRID_H] = False
          bc[c4d.SPLINECONTROL_GRID_V] = True
          bc[c4d.SPLINECONTROL_Y_MIN] = 0
          bc[c4d.SPLINECONTROL_Y_MAX] = 50
          bc[c4d.SPLINECONTROL_MINSIZE_V] = 10
          bc[c4d.SPLINECONTROL_GRIDLINES_V] = 50
          spl = self.AddCustomGui(SPG, 1009059, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0, bc)
          self.GroupEnd()
          self.LayoutChanged(1002)
      def InitValues(self) :
          self.SetTitle("Test")
          self.GroupEnd()
      def Command(self, id, msg) :
          global spl
          if id==BUTTON_1:
            print spl.GetGridLineCountV()
            spl.SetGridLineCountV(10)
    if __name__=='__main__':
      dlg = TestSplGui()
      #DLG_TYPE_MODAL = > synchronous dialog
      #DLG_TYPE_ASYNC = > asynchronous dialogs
      dlg.Open(dlgtype=c4d.DLG_TYPE_ASYNC, defaultw=800, defaulth=600)
    On 16/09/2012 at 03:25, xxxxxxxx wrote:
    Thank you for the replies.
    So, Maxon, if it is impossible to get access to that, why is it in the SDK?
    On 18/09/2012 at 02:08, xxxxxxxx wrote:
    It's in the SDK because (same as what Niklas said before) GeDialog.AddCustomGui() creates an instance of a SplineCustomGui in a dialog if you call it with CUSTOMGUI_SPLINE.
    But when you declare it in a description you don't have access to the SplineCustomGui, only the SplineData. In that case in the resource description file you can set the number of grid horizontal/vertical steps with GRIDSIZE_H/GRIDSIZE_V flags. You can look at the Spline Deformer resource file to see how a SPLINE description element can be declared: resource\modules\objects\res\description\osplinedeformer.res.
    On 18/09/2012 at 02:40, xxxxxxxx wrote:
    I have set the grid divisions in my description file.
    But my plugin creates sets of knots dynamically and I would like to match the grid divisions with the number of knots created.
    It is a shame that it can't be done :-(
