On 27/08/2012 at 11:07, xxxxxxxx wrote:
I would like to triangulate a spline. I use LineObject.Triangulate() for that and it's work well if I have only one segment.
If tey are more than one there is no function SetSegment to set the segments. How can I do ? (I don't want to use CallCommand or use an ExtrusionObject or other, I want realy triangulate into a PolygonObject)
Script example when a spline is active :
import c4d def main() : lo = c4d.LineObject(op.GetPointCount(),op.GetSegmentCount()) for i,p in enumerate(op.GetAllPoints()) : lo.SetPoint(i,p) poly = lo.Triangulate(0.0) doc.InsertObject(poly) c4d.EventAdd() if __name__=='__main__': main()
Thx
On 23/04/2013 at 22:45, xxxxxxxx wrote:
up ! anyone had an idea, or it's impossible ? (if it's impossible -> wishing list for r2015 with the possibility to create ngons ...)
On 24/04/2013 at 03:54, xxxxxxxx wrote:
why don't you just create multiple LineObject out of your SplineObject (where you do have full access to the spline (segment) data) in python? i am also not quite sure if converting the spline object control points into LineObject points is a very suitable approach for a practical plugin, as this will cause you to loose any interpolation.
ps : ' for r2015 with '. i would call that downright blasphemy
On 24/04/2013 at 08:49, xxxxxxxx wrote:
Originally posted by xxxxxxxx why don't you just create multiple LineObject out of your SplineObject
For "classical" segments it's not a problem. It's only when a segment is within an other, triangulate in C++ make a hole into the polygon in python no way ...
