Camera matrix during animation
On 26/08/2012 at 11:53, xxxxxxxx wrote:
Cinema 4D Version:   13
I'm trying to get the inverse camera matrix of the render basedraw for an animation export. I step through the animation keys of the active camera object:
doc->SetTime(bt); // Set Time to key->GetTime();
doc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0);
EventAdd(); // don't know whether that's required in this case
BaseDraw *bd = doc->GetRenderBaseDraw();
Matrix m = bd->GetMi();
The matrix won't change during animation. It keeps the values from the first frame! Do I have to send another kind of update message?
If I use the inverted global matrix of the camera object, it works, but I would prefer to use the matrix from the render basedraw.
On 01/09/2012 at 13:29, xxxxxxxx wrote:
I dunno if this will help or not, but after the EventAdd(), add this:
  DrawViews(DRAWFLAGS_FORCEFULLREDRAW | DRAWFLAGS_NO_THREAD, NULL);    // force completion of cache rebuild
...I use that sequence of calls when I'm dealing with animating the document.
On 01/09/2012 at 13:32, xxxxxxxx wrote:
...more specifically, I have a 'version compatibility' routine that I call...
// cmpAnimateDocument()
void cmpAnimateDocument(BaseDocument *pDoc, const BaseTime& frameTime)
//    StopAllThreads();
  pDoc->SetTime(frameTime);
#ifdef _R12_SDK_
  pDoc->ExecutePasses(NULL, TRUE, TRUE, TRUE, BUILDFLAGS_0);
#elif _R11p5_SDK_
  pDoc->ExecutePasses(NULL, TRUE, TRUE, TRUE);
#else
  pDoc->AnimateDocument(NULL, TRUE, TRUE);
#endif
  EventAdd();
#ifdef _R12_SDK_
#elif _R10p1_SDK_
  DrawViews(DA_FORCEFULLREDRAW | DA_NO_THREAD, NULL);
#else
  DrawViews(DA_FORCEFULLREDRAW);
#endif
On 02/09/2012 at 13:41, xxxxxxxx wrote:
OK, thanks. I'll try it tomorrow. But I dont't want the editor windows being redrawed since it's called very often.
