On 23/08/2012 at 06:12, xxxxxxxx wrote:
I'm creating a python plugin. The GUI is created in the code and not in a res file.
E.g. self.AddComboBox(MY_COMBOBUTTON, c4d.BFV_MASK) self.AddChild(MY_COMBOBUTTON, 0, "Add Selections") self.AddChild(MY_COMBOBUTTON, 1, "Substract Selections" )
How can I add a link box and then drag and drop objects into this linkbox?
_<_img src="http://chicagoc4d.com/c4dpythonsdk/_images/linkbox.png" height="30" width="193" border="0" /_>_
If have seen the documentation in the Cinema 4d Python Help, but I do not quite understand it. An example would be nice.
On 23/08/2012 at 06:33, xxxxxxxx wrote:
To add a linkbox in a dialog you have to use the custom LinkBoxGui. Here's how to create one:
self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
You can then call self.linkBox.GetLink()/SetLink() to get/set the linked object.
On 23/08/2012 at 07:17, xxxxxxxx wrote:
Thanks very much for the quick and clear reply. So this is what I have done:
def CreateLayout(self) : ... self.linkBox = self.AddCustomGui(MY_LINKBOX, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
and in def Command(self, id, msg) : ... print self.linkBox.GetLink()
What I find very odd, that the getlink does not need an ID. E.g. MY_LINKBOX. What if I like to use 2 linkboxes? How to distinguish them?
On 23/08/2012 at 07:54, xxxxxxxx wrote:
If you want to use 2 linkboxes I don't see where's the problem:
self.linkBox1 = self.AddCustomGui(MY_LINKBOX1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0) self.linkBox2 = self.AddCustomGui(MY_LINKBOX2, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0)
GetLink() doesn't need a linkbox ID because you call it over an instance of a LinkBoxGui.
On 24/08/2012 at 00:38, xxxxxxxx wrote:
Of course, clear. Thanks
On 01/01/2013 at 11:33, xxxxxxxx wrote:
Originally posted by xxxxxxxx If you want to use 2 linkboxes I don't see where's the problem: self.linkBox1 = self.AddCustomGui(MY_LINKBOX1, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0) self.linkBox2 = self.AddCustomGui(MY_LINKBOX2, c4d.CUSTOMGUI_LINKBOX, "", c4d.BFH_SCALEFIT|c4d.BFV_SCALEFIT, 0, 0) GetLink() doesn't need a linkbox ID because you call it over an instance of a LinkBoxGui.
Hi Yannick Puech, happy new year.
In .res there is a special code to enter?
my file .res:
LINK CASELLAPERSONALE { CENTER_V; ALIGN_LEFT; SIZE 218, 0; }
but not work....
On 01/01/2013 at 12:19, xxxxxxxx wrote:
Hi Caleidos4D, I got your private message.
I personally always use Add.... for dialogs. And only use the .res file for things like tags, tools, object's, etc...
GeDialog + .res = Hair Pulling
On 01/01/2013 at 13:24, xxxxxxxx wrote:
ah! OK!!! ScottA Thank you
