Watch Folder
On 13/08/2012 at 02:09, xxxxxxxx wrote:
Hey all,
I'm trying to write a script that watches a folder and looks for new C4D files. Once it finds a new file it should add the file to the render que. The code works fine in an external editor, however in C4D it doesn't work. When I run the script and add a new file to the watch folder, C4D hangs and I have to restart it.
Does anyone have a clue why? See the code below.
Greets,
Hans Willem
import os
import time
def watchFolder() :
    before = os.listdir('/Users/blabla/watch folder')
    while 1:
        global newFiles
        time.sleep(3)
        after = os.listdir('/Users/blabla/watch folder')
        newFiles = list(set(after)-set(before))
        if len(newFiles) > 0:
            renderFile()
            break
            before = after
def renderFile() :
    for i in newFiles:
        if i[-3:] =='c4d':
            # then some code here to add the file to the renderque and start rendering
    watchFolder()
watchFolder()
On 13/08/2012 at 03:27, xxxxxxxx wrote:
Of course it hangs, because you block the main thread. Put your code into a threaded environment. 🙂
For R13+, see the c4d.threading module which works afaik fine in the Script Manager. For R12, you'd need to write a plugin that uses the built-in threading module.
-Nik
