GetAllObjects()?
    On 09/08/2012 at 12:15, xxxxxxxx wrote:
    Hey all,
    I was wondering if there is a way to get all objects? I need python to know the total amount of objects in a scene. Regardless of wether they are in a hierarchy or not. Is there a way to do that?
    Greets!
    Hans Willem
    On 09/08/2012 at 12:36, xxxxxxxx wrote:
    Yes, there is.
    There are a lot of references for walking the hierarchy in the forum, the C++ documentation and I think also in the Python documentation.
    The easiest way to travel through the hierarchy is using a recursive function (half recursive, half iterative actually). You can also iterate through the whole hierarchy without doing a recursive function-call.
    -Niklas
    On 09/08/2012 at 23:28, xxxxxxxx wrote:
    Hi Hans,
    This is a great article with source code showing how to traverse all the objects in a document:
    http://www.peranders.com/w/index.php?title=Python_Object_Iteration
    On 09/08/2012 at 23:35, xxxxxxxx wrote:
    Ah! Thanks a lot guys! That will do the trick!
    Greets,
    Hans Willem
    On 02/10/2012 at 12:52, xxxxxxxx wrote:
    This is what I needed too.  Thank you PerAnders!  Actually if I might, I am just getting started and the link above is of enormous help.  For example, "How do I ???"  would be a great thread or set of threads to get us newbies up and running.  I figured out how to generate, assign, and change values of a texture before I actually found this about selecting objects in the OM.  I am traversing the learning curve one sample at a time... ;-)
