On 09/08/2012 at 05:54, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Windows ; Language(s) : C++ ;
--------- I'm working on a special material/shader combination. The material caches some data which I then need to access from the shader. So the shader must get a material-unique ID or the material object itself to gain access to the proper data. Do you have any idea how to do this?
On 09/08/2012 at 23:58, xxxxxxxx wrote:
The shader can just hold a BaseLink to the material and exchange data through messages. (If the code is in a different module, otherwise direct access is possible with just a pointer to the material.)
On 10/08/2012 at 12:56, xxxxxxxx wrote:
ok that's almost what I thought of. Thanks!
