On 08/08/2012 at 03:23, xxxxxxxx wrote:
I'm still confused about the GetDEnabling() thing, where we should include a call to the base-classes' method. There are several topics where the issue I'm currently having appears, and we couldn't find a solution to it. Yannick told me he couldn't ever reproduce this error, and as soon as I wanted to show him some code that triggers it, I couldn't reproduce it either.
But now I have a piece of code that invokes the error, and I don't really understand it. Sometimes the parent-call works, and sometimes it doesn't.
This is my code so far:
def GetDEnabling(self, op, descid, data, flags, itemdesc) : rid = descid[0].id value = True # Just like the original Cube primitive, we will disable PRIM_CUBE_SEP # when PRIM_CUBE_DOFILLET is active. if rid == c4d.PRIM_CUBE_SEP: value = not op[c4d.PRIM_CUBE_DOFILLET] # PRIM_CUBE_FRAD and PRIM_CUBE_SUBF will be disabled when # PRIM_CUBE_DOFILLET is not activeated. elif rid in (c4d.PRIM_CUBE_FRAD, c4d.PRIM_CUBE_SUBF) : value = op[c4d.PRIM_CUBE_DOFILLET] # NRPRIM_DCUBE_INNERFOFFSET will be disabled when PRIM_CUBE_DOFILLET # is not activated. elif rid == c4d.NRPRIM_DCUBE_INNERFOFFSET: value = op[c4d.PRIM_CUBE_DOFILLET] # Otherwise, ask your parents! else: print "-> Parent Call for id", rid value = super(DoubleCubeData, self).GetDEnabling(op, descid, data, flags, itemdesc) return bool(value)
Fine so far. It used to work some minutes ago, and then suddenly, it didn't work for some elements.
I have made a screencast that is intended to show the error more precisely and understandable. At the last part of the video, I do print "Parent call for id xx failed" when the parent-call failed. It will not be printed for some of the elements. That is because no parent-call is made for those elements (for example when I click in the "Seperate Surfaces" element or drag on the "Fillet Radius"). It seems like only the parent-call for the element that is currently being changed in the AM fails.
The video is located here.
Can someone enlighten me about the issue? -Niklas
On 08/08/2012 at 06:17, xxxxxxxx wrote:
Thanks for investigating this. Yes, I've now been able to reproduce this issue calling NodeData.GetDEnabling(). Please submit this bug.
