On 04/08/2012 at 09:21, xxxxxxxx wrote:
User Information: Cinema 4D Version: 13 Platform: Windows ; Mac OSX ; Language(s) : C++ ;
--------- Hi,
does anybody know, how to retrieve the proper values for the key tangents if the Auto Tangents option is activated (default)? The methods GetTimeLeft / GetTimeRight provide zero although the timeline shows the tangents with a length. The attribute manager also shows 0 in the disabled edit fields unless you disable Auto Tangents. Then the proper values are displayed.
I'm surprized, that the methods don't provide the right values, because I assumed, that these values are the ones internally used.
Any ideas?
Thanks, Klaus
On 06/08/2012 at 01:59, xxxxxxxx wrote:
Hi Klaus,
To get the proper values for the key, you can disable Auto Tangents in your code by calling:
key->ChangeNBit(NBIT_CKEY_AUTO,NBIT_DEL);
On 07/08/2012 at 02:58, xxxxxxxx wrote:
Hi Yannek,
thanks, but that doesn't work. NBIT_DEL is not defined, so I used NBITCONTROL_CLEAR. But key->GetRightTime() still provides zero for the first key.
Maybe there is a misunderstanding: I don't want to change the user's editings! But your answer leads me to GetNBit and that's ok to get the state. Then, the time values can be calculated.
