XPresso ports get disconnected on Undo
On 03/08/2012 at 01:36, xxxxxxxx wrote:
Hello dear MAXON support.
This tiny script here opens a modal dialog and after clicking ok, it changes the color of Nodes in the XPresso Manager of the selected XPresso Tag.
Question: Why are most of the nodes being disconnected when doing an Undo?
Animated PNG# coding: utf-8 # author: Niklas Rosenstein <rosensteinniklas@gmail.com> """ XPresso Node-Color Modificator ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1. Select an XPresso Tag (just a single tag) 2. Execute the script 3. Change the parameters 4. Press Ok 5. See changes in the XPresso Manager [6. Make an Undo and start from step 2 if you don't like the changes] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ This software comes AS IS and the author does not give ANY WARRANTY in MERCHANTIBILITY or FITNESS of the software. The author does not give ANY WARRANTY that the software will not make any damages to your software or hardware. """ import c4d import c4d.modules.graphview as c4dgv class Dialog(c4d.gui.GeDialog) : EDT_MUL = 1000 EDT_INCLROOT = 1001 EDT_MODROOTCOL = 1002 BTN_OK = 2000 BTN_CN = 2001 def __init__(self) : super(Dialog, self).__init__() self.ok = False self.data = {self.EDT_MUL: 0.5, self.EDT_INCLROOT: False, self.EDT_MODROOTCOL: False} def CreateLayout(self) : self.SetTitle("XPresso Node-Color") self.GroupBegin(0, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT) self.AddStaticText(0, c4d.BFH_LEFT, name="Multiplier") self.AddEditNumberArrows(self.EDT_MUL, c4d.BFH_SCALEFIT) self.AddCheckbox(self.EDT_INCLROOT, c4d.BFH_LEFT, initw=0, inith=10, name="Include Root") self.AddCheckbox(self.EDT_MODROOTCOL, c4d.BFH_LEFT, initw=0, inith=10, name="Modify Default Color") self.AddButton(self.BTN_OK, c4d.BFH_SCALEFIT, name="Ok") self.AddButton(self.BTN_CN, c4d.BFH_SCALEFIT, name="Cancel") self.GroupEnd() return True def InitValues(self) : self.SetReal(self.EDT_MUL, self.data[self.EDT_MUL], min=0, step=0.01) self.SetBool(self.EDT_INCLROOT, self.data[self.EDT_INCLROOT]) self.SetBool(self.EDT_MODROOTCOL, self.data[self.EDT_MODROOTCOL]) return True def Command(self, id, msg) : if id == self.EDT_MUL: self.data[id] = self.GetReal(id) elif id in (self.EDT_INCLROOT, self.EDT_MODROOTCOL) : self.data[id] = self.GetBool(id) elif id == self.BTN_OK: self.ok = True self.Close() elif id == self.BTN_CN: self.ok = False self.Close() return True def Open(self) : super(Dialog, self).Open(c4d.DLG_TYPE_MODAL, defaultw=200) def Succeeded(self) : return self.ok def GetResult(self) : return self.data def change_colors(node, data) : color = node[c4d.ID_GVBASE_COLOR] if color != data['root-col'] or data[Dialog.EDT_MODROOTCOL]: doc.AddUndo(c4d.UNDOTYPE_CHANGE, node) node[c4d.ID_GVBASE_COLOR] = color * data[Dialog.EDT_MUL] node.Message(c4d.MSG_CHANGE) for child in node.GetChildren() : change_colors(child, data) def main() : tag = doc.GetActiveTag() if not tag: print "No Tag selected." return if not tag.CheckType(c4d.Texpresso) : print "The selected Tag must be an XPresso Tag." return master = tag.GetNodeMaster() root = master.GetRoot() dlg = Dialog() dlg.Open() if not dlg.Succeeded() : return data = dlg.GetResult() data['root-col'] = root[c4d.ID_GVBASE_COLOR] if data[Dialog.EDT_INCLROOT]: change_colors(root, data) else: for child in root.GetChildren() : change_colors(child, data) c4d.EventAdd() if __name__ == "__main__": main()
Thank you very much in advance,
Nik
On 06/08/2012 at 01:48, xxxxxxxx wrote:
Ok, I got it. Instead of calling BaseDocument.AddUndo() for every change, we should call GvNodeMaster.AddUndo() at the state where the Undo-Action should lead. So, just call it before any node is manipulated and it works fine. No call to BaseDocument.AddUndo() is necessary anymore.
# coding: utf-8 # author: Niklas Rosenstein <rosensteinniklas@gmail.com> """ XPresso Node-Color Modificator ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ 1. Select an XPresso Tag (just a single tag) 2. Execute the script 3. Change the parameters 4. Press Ok 5. See changes in the XPresso Manager [6. Make an Undo and start from step 2 if you don't like the changes] ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ This software comes AS IS and the author does not give ANY WARRANTY in MERCHANTIBILITY or FITNESS of the software. The author does not give ANY WARRANTY that the software will not make any damages to your software or hardware. """ import c4d import c4d.modules.graphview as c4dgv class Dialog(c4d.gui.GeDialog) : EDT_MUL = 1000 EDT_INCLROOT = 1001 EDT_MODROOTCOL = 1002 BTN_OK = 2000 BTN_CN = 2001 def __init__(self) : super(Dialog, self).__init__() self.ok = False self.data = {self.EDT_MUL: 0.5, self.EDT_INCLROOT: False, self.EDT_MODROOTCOL: False} def CreateLayout(self) : self.SetTitle("XPresso Node-Color") self.GroupBegin(0, c4d.BFH_SCALEFIT | c4d.BFV_SCALEFIT) self.AddStaticText(0, c4d.BFH_LEFT, name="Multiplier") self.AddEditNumberArrows(self.EDT_MUL, c4d.BFH_SCALEFIT) self.AddCheckbox(self.EDT_INCLROOT, c4d.BFH_LEFT, initw=0, inith=10, name="Include Root") self.AddCheckbox(self.EDT_MODROOTCOL, c4d.BFH_LEFT, initw=0, inith=10, name="Modify Default Color") self.AddButton(self.BTN_OK, c4d.BFH_SCALEFIT, name="Ok") self.AddButton(self.BTN_CN, c4d.BFH_SCALEFIT, name="Cancel") self.GroupEnd() return True def InitValues(self) : self.SetReal(self.EDT_MUL, self.data[self.EDT_MUL], min=0, step=0.01) self.SetBool(self.EDT_INCLROOT, self.data[self.EDT_INCLROOT]) self.SetBool(self.EDT_MODROOTCOL, self.data[self.EDT_MODROOTCOL]) return True def Command(self, id, msg) : if id == self.EDT_MUL: self.data[id] = self.GetReal(id) elif id in (self.EDT_INCLROOT, self.EDT_MODROOTCOL) : self.data[id] = self.GetBool(id) elif id == self.BTN_OK: self.ok = True self.Close() elif id == self.BTN_CN: self.ok = False self.Close() return True def Open(self) : super(Dialog, self).Open(c4d.DLG_TYPE_MODAL, defaultw=200) def Succeeded(self) : return self.ok def GetResult(self) : return self.data def change_colors(node, data) : color = node[c4d.ID_GVBASE_COLOR] if color != data['root-col'] or data[Dialog.EDT_MODROOTCOL]: node[c4d.ID_GVBASE_COLOR] = color * data[Dialog.EDT_MUL] node.Message(c4d.MSG_CHANGE) for child in node.GetChildren() : change_colors(child, data) def main() : tag = doc.GetActiveTag() if not tag: print "No Tag selected." return if not tag.CheckType(c4d.Texpresso) : print "The selected Tag must be an XPresso Tag." return master = tag.GetNodeMaster() root = master.GetRoot() master.AddUndo() dlg = Dialog() dlg.Open() if not dlg.Succeeded() : return data = dlg.GetResult() data['root-col'] = root[c4d.ID_GVBASE_COLOR] if data[Dialog.EDT_INCLROOT]: change_colors(root, data) else: for child in root.GetChildren() : change_colors(child, data) c4d.EventAdd() if __name__ == "__main__": main()
Thanks goes to Sebastian (s_rath).
Niklas
