On 02/08/2012 at 13:16, xxxxxxxx wrote:
User Information: Cinema 4D Version: R13 Platform: Mac OSX ; Language(s) : C++ ;
--------- Hi, I have a question about C++ plugins: are there any possibility to know if rendering in Picture Viewer is done?
I have achieved it with a VideoPost plugin Execute and VIDEOPOSTCALL_FRAMESEQUENCE, which i found here, but it seams that the message is sent after the last frame is rendered, but before saving it to the disk. So if the frame is very big - Picture Viewer is still doing something (in this case - writing an image to the disk) and I've already received VIDEOPOSTCALL_FRAMESEQUENCE message.
Are there any way to know if the rendering is totally finished? (rendering + saving to disk + whatever Picture Viewer is doing after rendering)
Thank you for all the answers in advance
P.S.: Sorry if my question is totally stupid - I'm building my first plugin in C4D
On 03/08/2012 at 01:23, xxxxxxxx wrote:
You must check for the value of VideoPostStruct::open member. It's FALSE for closing calls and TRUE for opening calls.
Example:
RENDERRESULT MyVideoPost::Execute(BaseVideoPost *node, VideoPostStruct *vps) { if (vps->vp==VIDEOPOSTCALL_FRAMESEQUENCE && !vps->open && *vps->error==RENDERRESULT_OK && !vps->thread->TestBreak()) { ...
On 03/08/2012 at 03:48, xxxxxxxx wrote:
Thank you, Matthias, but I'm checking open member already:
RENDERRESULT MyVideoPost::Execute(BaseVideoPost *node, VideoPostStruct *vps) { if(vps->vp != VIDEOPOSTCALL_FRAMESEQUENCE) { return RENDERRESULT_OK; } if(vps->open) { return RENDERRESULT_OK; } else { if(vps->renderflags & RENDERFLAGS_EXTERNAL) { // Rendering in picture viewer is done. // Send message. SpecialEventAdd(MYVIDEOPOST_ID); } } return RENDERRESULT_OK; }
I expect SpecialEventAdd(MYVIDEOPOST_ID) call only when picture viewer is finished, but it is not.
If in the other place, when I get CoreMessage with MYVIDEOPOST_ID, I call CallCommand(12099) to start rendering again - Picture Viewer asks if I need to stop previous rendering... So, as I understand, I can not identify if rendering is done this way.
Thanks, Simonas
On 03/08/2012 at 04:45, xxxxxxxx wrote:
You need to check for VIDEOPOSTCALL_FRAMESEQUENCE AND !vps- >open if rendering is finished. Please have a look again at my example, it's checking if rendering is finished.
On 03/08/2012 at 11:59, xxxxxxxx wrote:
Sorry Matthias that I'm still struggling and wasting your time I know my code posted above may look awkward but it works almost the same way you suggested.
Any way - I have rewritten it as you suggested, but the problem does not disappear.
RENDERRESULT MyVideoPost::Execute(BaseVideoPost *node, VideoPostStruct *vps) { if(vps->vp==VIDEOPOSTCALL_FRAMESEQUENCE && !vps->open && *vps->error==RENDERRESULT_OK && !vps->thread->TestBreak()) { // Rendering in picture viewer is done. // Send message. SpecialEventAdd(RENDERMASTER_VIDEOPOST_ID); } return RENDERRESULT_OK; }
On 09/08/2012 at 07:31, xxxxxxxx wrote:
Hi Simonas,
Here's more information I got from the developers:
If you are in VideoPost::Execute() the render process is still ongoing (even if it is shortly before exiting), so stopping it will ask if the current render shall be stopped. If you set RDATA_FINISHMESSAGE in the render settings to TRUE, then you'll get a message EVMSG_RAYTRACER_FINISHED at a much later time, however even then the render thread needs a couple more milliseconds to exit.
The only reliable way is to set a (global) finished flag either in VideoPost::Execute() or EVMSG_RAYTRACER_FINISHED (better) and then periodically check (using a timer in a message plugin) if the rendering is done (calling CheckIsRunning()). It also would be possible to just surveil CheckIsRunning() in a message plugin.
On 11/08/2012 at 08:36, xxxxxxxx wrote:
Super duper - it works!
Thanks Yannick - you saved my life
