On 02/08/2012 at 07:36, xxxxxxxx wrote:
I'm just curious of why NodeData.Init() is called multiple times. I could figure out the following cases that invoke that the method is called:
Is this supposed to be? It looks like a heavy overhead to me. I can reproduce this in all versions from R12 to R14.
Thanks in advance, -Niklas
On 02/08/2012 at 13:54, xxxxxxxx wrote:
In several cases its because the object is moved to the undo stack and therefore a new one must be created and initialized as well.
Cheers, Sebastian
On 03/08/2012 at 01:14, xxxxxxxx wrote:
Thank you Sebastian, I understand.
-Nik
