Why use InitAttr ?
On 31/07/2012 at 18:35, xxxxxxxx wrote:
To initialize the elements of the description of my tag, should I use something like:
def Init(self,node) :
     data = node.GetDataInstance()
     data.SetData(SD_ON,True)
or something like:
[COLOR=blue]
def Init(self, node) :
    self.InitAttr(host=node, type=bool, desc=[SD_ON])
    node[SD_ON] = True
What is the difference?
On 31/07/2012 at 19:50, xxxxxxxx wrote:
You only need self.InitAttr() for initializing GUI elements,
then setting the values to the GUI's.
Regular values you set directly using your IDs.
Such as:
     def Init(self, pconnector) :
          pconnector[DIRTYSUM]               = c4d.BaseContainer()
          # Source Settings
          pconnector[c4d.PC_SHIDE]          = True
          pconnector[c4d.PC_MODE_ALL]          = 0
          pconnector[c4d.PC_AMOUNT]          = 1.0
          pconnector[c4d.PC_CONNECT]          = 0
          # Point Settings
          pconnector[c4d.PC_STARTPOINT]            = 1.0
          pconnector[c4d.PC_ENDPOINT]             = 100.0
          pconnector[c4d.PC_OFFSETPOINT]           = 0.0
          pconnector[c4d.PC_DIRECTION]             = 0
          pconnector[c4d.PC_POINTSTEP]             = 1.0
          pconnector[c4d.PC_CONNECTSTEP]           = 1.0
          pconnector[c4d.PC_MAXPOINTDIF]           = 1000.0
          pconnector[c4d.PC_RANDOM]          = 0.0
          # Spline Settings
          pconnector[c4d.PC_MAKESPLINE]          = True
          pconnector[c4d.PC_SPLINE_MIN]          = 0.0
          pconnector[c4d.PC_SPLINE_MAX]          = 1000.0
          pconnector[c4d.PC_SEGMENT_START]     = 0.0
          pconnector[c4d.PC_SEGMENT_END]          = 1.0
          pconnector[c4d.PC_DISTANCE_GROW]     = 0
          pconnector[c4d.PC_DISTANCE_SENSE]     = 0.8
          pconnector[c4d.PC_SPLINE_SUB]          = 0
          #TP life
          self.InitAttr(pconnector, c4d.SplineData, [c4d.PC_TPCURVE])
          icurve = pconnector[c4d.PC_TPCURVE]
          icurve.SetRange(0.0, 1.0, 0.01, 0.0, 1.0, 0.01)
          icurve.InsertKnot(1,1,0)
          icurve.InsertKnot(0,1,0)
          pconnector[c4d.PC_TPCURVE] = icurve
          # General
          pconnector[c4d.PC_SPACE]          = 0
          pconnector[c4d.PC_CACHE]          = False
          pconnector[c4d.PC_INFO]               = 'Ready'
          #etc
Lennart
On 31/07/2012 at 20:00, xxxxxxxx wrote:
I have been initializing the values of the GUI elements of the description in the Init method, using:
     data.SetData(SD_USE_CHILDREN,False)
     data.SetData(SD_NO_INTERPOLATE,False)
     data.SetData(SD_INSTANCES,False)
     data.SetData(SD_DRAW_SPHERES,True)
Is this incorrect?
On 31/07/2012 at 20:17, xxxxxxxx wrote:
It's incorrect as we are not recommended to use the basecontainer (.GetDataInstance()).
What I mean by GUI elements is things like the Spline GUI, it is just the
"background" that holds no values. It needs to get the values set as you can see
in my example before.
Your init should/could look:
     node[c4d.SD_ON] = True
     node[c4d.SD_USE_CHILDREN] = False
     node[c4d.SD_NO_INTERPOLATE] = False
     node[c4d.SD_INSTANCES] = False
     node[c4d.SD_DRAW_SPHERES] = True
..given the ID's are in your res/str/.h files
Lennart
On 31/07/2012 at 20:18, xxxxxxxx wrote:
Much simpler 🙂
Thank you, Lennart.
