On 31/07/2012 at 18:28, xxxxxxxx wrote:
How can I deactivate an element from a description of an TagData tag? I want to be able to, dynamically, activate and deactivate some elements, based on if some checkmarks are on or off.
On 31/07/2012 at 19:11, xxxxxxxx wrote:
The topic was up a short while ago. https://plugincafe.maxon.net/topic/6478/6965_deschide-and-desceditable
An example:
# Testing gray out controllers def GetDEnabling(self, node, id, t_data, flags, itemdesc) : if (id[0].id == c4d.PC_SPLINE_MIN ) : return node[c4d.PC_MAKESPLINE] == 1 if (id[0].id == c4d.PC_SPLINE_MAX ) : return node[c4d.PC_MAKESPLINE] == 1 return True
From a user point of view, make sure you're not greying out parameters that a user may to edit prior to engage. For example if gigantic calculation is included, it may be that the user wants to lower a value before engaging it. Just a thought..
Cheers Lennart
On 31/07/2012 at 19:54, xxxxxxxx wrote:
Thank you very much, Lennart. It worked great. However, this method is new in version R13.029 Was this impossible to do in versions prior to 13?
Rui Batista
On 31/07/2012 at 20:19, xxxxxxxx wrote:
I guess if it was not implemented until 13.029 it's not available for earlier versions. But the 13.xxx are free updates, so I can't see the problem?
On 01/08/2012 at 03:17, xxxxxxxx wrote:
The problem is that people using R12 (that are still a lot) can't use my plugin
On 01/08/2012 at 06:29, xxxxxxxx wrote:
They can, but the dimming-stuff will not be available to them.
On 01/08/2012 at 08:31, xxxxxxxx wrote:
I figured I wouldn't make a new topic since it's similar to this. When dealing with a Dialog that's called by a command plugin , is it possible to hide some of the gadgets with something similar to [c4d.DESC_HIDE]? So when you check a box some controls appear or disappear? Is that what GetDEnabling is used for?
Dan
On 01/08/2012 at 09:16, xxxxxxxx wrote:
You can only disable/enable gadgets in your dialog. For hiding them, you would need to really remove them as gadgets, and add them when you need them again.
GetDEnabling is a function that you can override only for NodeData plugins (i.e. Objects, Tags, ..). It is not available in a CommandData plugin.
-Nik
On 01/08/2012 at 12:57, xxxxxxxx wrote:
Thanks, Niklas.
So something like:
self.LayoutFlushGroup(ControlsToDisable) self.LayoutChanged(ControlsToDisable)
to disable a group, and
#Some sort of code to add new controls and then self.LayoutChanged(ControlsToEnable)
Is there a way to save a a gadget in a variable, so if I disable it I could re-enable it later with the same value and settings?
