Set Keys, Interpolation problems
On 30/07/2012 at 12:25, xxxxxxxx wrote:
Has anyone done a straight simple SetKeys Command using DescID(DescLevel)
for the length of a scene without any issues in that the original
keys interpolation is not messed up?
(Basically baking parameters).What I thought was pretty straight forward have had me in a loop for
a couple of days.Simple scenario, set regular key at frame 0 and another one at the end of scene
using Linear interpolation in Project settings.Then run a set keys (Baking) command that that sets a key for each frame.
The result for me is that the keys are -not- linear (following the original curve)
but in a easein shape.Using three keys, the set keys are in a easein shape between existing original keys.
Lennart
On 31/07/2012 at 08:01, xxxxxxxx wrote:
Apparently, for me, setting keys for each frame on the same track I'm
reading from, does make the interpolation faulty.
Setting keys for an object without tracks/keys, i.e. is driven by expressions,
all work as it should.
This was my intention (bake expression driven objects) but when trying to
bake already key framed objects, I ran into this issue.
I guess for those cases I need to work on some sort of copy.Cheers
Lennart
