UV Mirror H&V
    On 26/07/2012 at 13:29, xxxxxxxx wrote:
    ..just another comment/suggestion...
    If you're going to be calling Get()/Set() on the UVWTag (and/or looping through all the uv-polys), then you typically don't need to do the GetActiveUVSet() stuff... that's mostly useful when you need to know which uv-polys/points are currently selected or if you want to work with the arrays directly (uvhandle->GetUVW() / uvhandle->SetUVW()).
    The reason it's needed for 'selected uv-points', for example is that... there are basically 4 uv-points per uv-polygon - which may be a far different number (and different indexing) than the total number of points/vertices of the mesh (a cube has 8 vertices, but it has 6 * 4 = 24 uv-points).
    On 26/07/2012 at 16:08, xxxxxxxx wrote:
    Ah ha.
    Now I think I see what I'm doing wrong. I was assigning variables incorrectly.
    Here's a working version of my previous example:
        BaseObject *obj = doc->GetActiveObject();
      if(!obj)return FALSE;
      PointObject *pobj = ToPoint(obj);           //Cast the BaseObject type to a PointObject type and assign it to a variable "pobj"
      Vector *points = pobj->GetPointW();         //Get the array of points in the object(returns their vector positions)
      LONG count = pobj->GetPointCount();
      BaseContainer bc;                                                //Create an empty container..We'll use this to change some UV attributes
      TempUVHandle *handle = GetActiveUVSet(doc, GETACTIVEUVSET_ALL);  //Create an instance of the TempUVHandle class
      if (!handle) return FALSE;
      UVWTag *uvwtag = (UVWTag* )(pobj->GetTag(Tuvw, 0));         //The UVW tag that's on the object
      UVWHandle UVpolys = uvwtag->GetDataAddressW();             //The array of polygons in the UVWtag
      LONG UVpolycount = handle->GetPolyCount();                 //The number of UVpolygons
      UVWStruct res;                                             //An empty struct that we will eventually store the UV values in
        //To access the points in the UV polygons. Use res.a, res.b, res.c, res.d
      for (LONG i=0; i<UVpolycount; i++)
        LONG polyindx = i;                              //Assign the polygon's index# to a variable
        uvwtag->Get(UVpolys,i,res);                     //Store the polygon UVW info into the variable "res" for each UVpolygon
        //UVWTag::Get(UVpolys, i, res);                 //Alternative way to do the same thing
        res.a.x = 0.5;                                  //Move the vertex res.a.x to 0.5 on the canvas
        uvwtag->Set(UVpolys,i,res);                     //Update the changes to the UVpolygon in the UVW tag
        GePrint("ID#: " + LongToString(polyindx));
        GePrint("AX: " + RealToString(res.a.x) +".... " + "AY: " + RealToString(res.a.y));
        GePrint("BX: " + RealToString(res.b.x) +".... " + "BY: " + RealToString(res.b.y));
      FreeActiveUVSet(handle);                  //Free the memory
      pobj->Message(MSG_UPDATE);
      uvwtag->Message(MSG_UPDATE);
      EventAdd();
    Now all I need is a way to execute those UV projection buttons.
    If it's even possible.
    Thanks a lot Giblet,
    On 27/07/2012 at 05:14, xxxxxxxx wrote:
    Seems like the only open problem are the UV projection buttons. Btw. I was wrong about CallUVCommand and UV projections. I can't find a way to call them through the API. It looks like you need to do on your own. There is some example code about projections in the TexData structure documentation.
    If I've find a simpler way I will get back to it.
    cheers,
    Matthias
    On 27/07/2012 at 07:27, xxxxxxxx wrote:
    I was pretty sure that was going to be your answer Matthias.
    But sometimes you manage to pull a secret button command out of your bag of tricks. So I had to ask.
    Body Paint seems to be much less supported by the SDK than the rest of the program.
    It's been totally ignored for the last few updates. So maybe someday if they go back to it they will also add SDK support for all of the buttons.
    Giblet provided some code about Frontal projecting. That's the only one I really was interested in anyway. So I'll study what he provided and see if I can learn how to do it.
    Thanks for the help,
    On 27/07/2012 at 08:17, xxxxxxxx wrote:
    Originally posted by xxxxxxxx
    ...Giblet provided some code about Frontal projecting...
    ... that code was originally (at least partially) based on the example code that Matthias mentions above, btw.
    On 27/07/2012 at 08:54, xxxxxxxx wrote:
    ^ I actually just got finished with your mapping code Giblet.
    I had to strip out a lot of the version checking stuff to make easier to read and see what it is doing.
    Unfortunately. The result isn't Frontal mapping. It's more like Flat mapping.
    As far as I can tell. Your code seems to get the size of the UV canvas then it runs through the UV's and places the UV points at the UV canvas boundaries...Thus producing the same result as the Flat button.
    I think the "Front" mapping button does a ray projection to get the object's points.
    Then passes them to the UV points so the UV's match the orientation of the object in the scene view.
    So I think I need to use: RayParameter *param=sd->GetRayParameter();
    This might be a bit over my head. But I'll try to figure it out.
    On 27/07/2012 at 09:38, xxxxxxxx wrote:
    Actually... yeah, if you just pass in the mesh's global matrix, you end up with a (frontal) Flat-mapping.  You could manipulate the matrix passed in to account for the camera orientation (no need for ray-tracing).
    I usually figure out matrix operations by trial-and-error (which I can't do right now), but basically, you need to combine the Inverse Camera matrix with the mesh's global (if you want to account for current mesh rotations) or local matrix...
      Matrix invCam = !pBaseDoc->GetActiveBaseDraw()->GetMg(); // inverse camera matrix
      // you may or may not also need to zero out the translation vector before combining...
      // invCam.off = Vector();
      Matrix mCombine = op->GetMg() * invCam;
      // or possibly...
      // Matrix mCombine = invCam * op->GetMg();
    ..then pass mCombine to that routine instead of op->GetMg()
