On 17/07/2012 at 00:05, xxxxxxxx wrote:
Hi everybody,
I've a problem with the flags of the C4DAtom.CopyTo()-function. The Python SDK says that there are a few optional flags for this function. But always I'm trying to use one of them I get the error message: 'module' object has no attribute 'COPY_NO_HIERARCHY'.
So I thougt: ok, then try it without using a flag. But the result was the error message: Required argument 'flags' (pos2) not found.
?? I thougt this parameter is optional?? Don't understand, how I can get this function working.
Does anybody else have an idea?
Here a small code snippet:
childs = obj[0].GetChildren() splineSegment = c4d.BaseObject(c4d.Ospline) if childs[seg].GetType() == splineSegment.GetType() : childs[seg].CopyTo(splineSegment,flags=c4d.COPY_NO_HIERARCHY)
cheers, sven
On 17/07/2012 at 00:23, xxxxxxxx wrote:
Hi, the flag is indeed undefined in R13. Please use COPYFLAGS_ instead of COPY_.
Will be fixed soon.
Cheers, Sebastian
On 17/07/2012 at 00:48, xxxxxxxx wrote:
Hi Sebastian,
this was the first idea of mine, too. But then i got the message, that c4d.SplineObject isn't alive anymore a few lines later.
Here are the following lines, that in this case doesn't work as the result:
splineSegment[c4d.ID_BASELIST_NAME] = "aktives Segment" splineSegment[c4d.ID_BASEOBJECT_USECOLOR] = True splineSegment[c4d.ID_BASEOBJECT_COLOR] = c4d.Vector(1,0,0)
For me it seems that with COPYFLAGS_NO_HIERARCHY not C4DAtom.CopyTo() isn't used but NodeData.CopyTo() instead.
What do you think about it?
Cheers, Sven
Edit: ah, i see. NodeData.CopyTo() requires more parameters so it must be C4DAtom.CopyTo(). But isn't alive anymore is a strange result to me. Hm, I see it in the object manager...
