On 16/07/2012 at 11:45, xxxxxxxx wrote:
User Information: Cinema 4D Version: 12 Platform: Windows ; Language(s) : C++ ;
--------- GetAllTextures() now requires pointing to an array. So now the code examples posted in the archives no longer works for me. I can't get any textures to return from it using the old code:
AutoAlloc<AtomArray> myArray; //Create a new empty atom type array if(myArray) { doc->GetActiveObjects(*myArray,FALSE); //Get any active objects and store them in the array (use GETACTIVEOBJECTFLAGS_0 for R13) LONG cnt = myArray->GetCount(); //Returns the size of the array based on how many objects are selected for(LONG i = 0L; i != cnt; ++i) { String name = static_cast<BaseObject*>(myArray->GetIndex(i))->GetName(); //Get the name of each selected object GePrint(name); } } ////// Great..Everything is working properly so far /////// ////// Now lets check to see what textures are assigned to the selected objects //////// BaseContainer bc = doc->GetAllTextures(myArray); //Create a container pointing to the array of selected objects BrowseContainer browse(&bc); //Create an instance of the BrowseContainer class LONG cid; GeData *data; while(browse.GetNext(&cid, &data)) { GePrint("found a texture"); //<---I get nothing in the console...Even with this!? Filename fn = data->GetFilename(); GePrint("Texture: " + fn.GetString()); }
Could someone please post a working example of GetAllTextures() that works with R12 and/or R13?
On 17/07/2012 at 14:22, xxxxxxxx wrote:
I finally figured out how to make it work. This code gets all the textures in the scene. And prints the names of any selected objects:
AutoAlloc<AtomArray> myArray; //Create a new empty atom type array if(myArray) { BaseContainer bc = doc->GetAllTextures(myArray); //Fill a new container with all the texures in the document LONG counter = 0; while(bc.GetIndexId(counter) != NOTOK) //Get all of the non-empty container items { counter++; Filename fn = bc.GetFilename(counter,NULL); //Get each container item that is a Filename type GePrint(fn.GetString()); } doc->GetActiveObjects(*myArray,FALSE); //Get any active objects and store them in the array(use GETACTIVEOBJECTFLAGS_0 for R13++) LONG objcnt = myArray->GetCount(); //Get the size of the array based on how nay objects are selected for(LONG i = 0L; i<objcnt; ++i) { String name = static_cast<BaseObject*>(myArray->GetIndex(i))->GetName(); //Get the names of the selected objects GePrint(name); } }
