BaseSelect updated, plus questions!
On 13/07/2012 at 10:55, xxxxxxxx wrote:
So I was toying around with BaseSelect and except for this thread:https://plugincafe.maxon.net/topic/5803/5859_creating-selection-tags I couldn't find much information about it, so I did some tests and I figured I'd post what I learned up here so it could help somebody.
Here's the script:
from c4d import gui
def main() :
  obj = doc.GetActiveObject() #Get active object
  doc.SetMode(c4d.Mpoints)
  if obj == None:
  c4d.CallCommand(12236)#Make the object editable
  SelectedPoints = obj.GetPointS()  #Creates an instance of the objects selection
  TotalPoints = obj.GetPointCount()#You need this to loop through and check all the points
  OriginalSelection = []
  SecondSelection =[]
  ThirdSelection = []
  print "Number of Points selected:",SelectedPoints.GetCount()#The number of points selected
  print "Point states at the beginning:"
  for id,state in enumerate(SelectedPoints.GetAll(TotalPoints)) :#prints out the id and the state of that point
      print "ID ",id,"State", state#The id of the point and whether it's selected or not
      if SelectedPoints.IsSelected(id) == True:
          OriginalSelection.append(id)#Creates a list of all the currently selected points Saving the current stat
  print  "List of the selected points:",OriginalSelection #The points that are slection
  for id in range(TotalPoints) :
      if SelectedPoints.IsSelected(id) == False:
          SelectedPoints.Select(id)#Select point 0 in addition to the runs already selected
          SecondSelection.append(id)
          break
  print "Point states at the middle:"
  print "List of the selected points:",SecondSelection #The points that are slection
  for id in OriginalSelection:
      SelectedPoints.Deselect(id)#Deselects the orginal selection
  #So the new point is what's selected
  SelectedPoints.ToggleAll(TotalPoints,0)
  #Swaps all the points to the opposite state,
  #The SDK is incorrect, the max goes first and then the min,ToggleAll(max,min)
  #SelectAll() has the same mistake, it should be SelectAll(max, min)
  print "Point states at the end:"
          ThirdSelection.append(id)
  print "List of the selected points:",ThirdSelection
if __name__=='__main__':
It's just run on an object and prints out some information on which points are selected.  It doesn't actually do anything but select different points though.  ToggleAll() and SelectAll() had me stumped for a bit because the SDK has incorrect information about them.
Anything I missed would be appreciated.
Daniel
Edit: So I've been trying to use BaseSelect to keep track of edges.  Are edges stored as two separate 'id's in the BaseSelect?  It doesn't seem to correspond with the points that form the line.   Even if they don't correspond to the points is there a reason for which 'id's are used?  GetCount() for BaseSelect also seems to double the number of edges that are actually selected, because it says two 'id's have the same edge.
from c4d import gui
def main() :
  edges = obj.GetEdgeS()
  edgecount = edges.GetCount()
  print "Number of edges selected", edgecount
  print edges.GetAll(50)
I need a way to select specific edges that works in both R13, and in R12.
Daniel
On 06/08/2012 at 09:23, xxxxxxxx wrote:
I think you should take a look at this interesting topic about BaseSelect and the edges of a mesh: https://plugincafe.maxon.net/topic/6226/6566_getedgecount--bug
I'll fix the documentation. Thanks for reporting these errors.
